New Projector. Cable Question..
Discussion in 'Cables & Switches' started by Rhyas, Jan 6, 2005.
  1. Rhyas
    Rhyas
    A Quick search didn't come up with anything, so...
    I just installed a Dell 2300MP. It's got several inputs, including what appears to be a DB15HD. It comes with an adapter to go from D-Sub (DB15) -> Component (RGB). The question I have is, can I extend the D-Sub 50 feet or so to where my equipment is, so I can use a media PC directly, and/or the adapter for component video from the wall near the equipment? Or should I use the short adapter at the projector and extend the component instead, then use another Component->VGA cable to connect the media pc from there?
    -= Jay =-
