New problem on my 360 please help!!
Discussion in 'Xbox Forums' started by gilford, Mar 22, 2006.
  1. gilford
    gilford
    Feb 12, 2005
    7,611
    Welsh riviera........
    +1,016
    I have now downloaded 2 demo's from the marketplace and I keep getting this error -
    This game does not support PAL-50. Please change your display settings to PAL-60. To change your setting, in System, select console settings, display.
    Now then, when I follow those instructions (to the T I might add) there is no option there???
    I have downloaded stuff before and it was ok?
    Any info appreciated :suicide:
  2. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    I believe you will have to switch the 'hdtv' option off on the video cable, then the option for pal-60 should be selectable.
  3. gilford
    gilford
    Feb 12, 2005
    7,611
    +1,016
    What good is that when I'm outputting everything on my HD plasma at 720p?
    Surely the game cant be in SD? This seems ridiculous, I downloaded Fight Night Round 3 and thast was ok in HD?
    Thanks for the info though :)
  4. oddfeld
    oddfeld
    Jan 5, 2006
    302
    28
    Edinburgh
    +53
    No, you can change the cable back to HD once you've changed SD to be PAL-60. I think 720p is always 60Hz, it's just an annoying dashboard bug.
  5. gillette 73
    gillette 73
    Feb 19, 2006
    717
    up north
    +77
  6. gilford
    gilford
    Feb 12, 2005
    7,611
    +1,016
    Cheers for the info! :)
    Got it to work. Anyone know why you have to do that though? It made me realise how bad SD really is :(
  7. Dave
    Dave
    Jul 3, 2005
    11,496
    163
    +3,401
    The games are only compatible with US TV's which use 60hz. The developers need to put support there for 50hz, or maybe MS need to sort it out.
    Who knows, seems kind of lazy to me to not make it work in most of Europe.
