new pro scan prob
Discussion in 'Projectors, Screens & Video Processors' started by clancol, Sep 13, 2003.
  1. clancol
    clancol
    Sep 6, 2003
    1,023
    38
    Middlesbrough
    +7
    Ok i thought i knew all about pro scan but i find it hard to work this out.
    I know that ps dvd players output either pal or ntsc. and i know the difference in the resolutions frame rate and such.
    but i thought that if the display could accept ntsc ps then it would
    be able to accept pal ps without extra technology.
    in this case i am on about the new tosh ####36 reap pro series.
    So basicly what does the tv have to do to accept pal PScan that it doesn't do to accept Ntsc.
    This just seems like another hurdel for us to jump.
    and do u think there will be a way round this stupidly annoying thing.
    Why do companies think that its o.k to give is half rated productes compared to other ereas of the world. whats the cost of a dvi input board. and ps for pal?
    Im a bit fed up.
    If one company could actualy give us what we want. instead of making us wait silly times they could rule the world of av.
  2. clancol
    clancol
    Sep 6, 2003
    1,023
    38
    Middlesbrough
    +7
    cancel all that.
    I get it now
    yea
  3. PAUL RODGERS
    PAUL RODGERS
    Sep 14, 2003
    159
    manchester
    I MAY BE STUPID BUT I AM HAVING A PROBLEM WITH PAL PROGRESSIVE SCAN ON MY PLASMA IS THERE ANYTHING I CAN DO
  4. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Helps if you tell us what equipment you're using PAUL RODGERS
  5. PAUL RODGERS
    PAUL RODGERS
    Sep 14, 2003
    159
    manchester
    EQUIPMENT IS
    1.L&G MZ42PZ17 PLASMA
    2.DENON DVD 2900
  6. clancol
    clancol
    Sep 6, 2003
    1,023
    38
    Middlesbrough
    +7
    i dont think the lg plasma eccepts pal ps.
    try turning the plasma and the player to ntsc-pal modes and so on
    managed to get it working in the store but can't remeber which combanation it was in.
    keep changing the settings yous should work it out.
  7. PAUL RODGERS
    PAUL RODGERS
    Sep 14, 2003
    159
    manchester
    THANKS FOR THE ADVICE.
    THE ONLY PROBLEM IS THE PLASMA DOES NOT GIVE YOU THE OPTION OF PAL OR NTSC
  8. clancol
    clancol
    Sep 6, 2003
    1,023
    38
    Middlesbrough
    +7
    well it must be an option with the dvd player. as
    we definatly had pal progressive workin with that plasma. i think it will have to be the pal-ntsc option.
  9. PAUL RODGERS
    PAUL RODGERS
    Sep 14, 2003
    159
    manchester
    what dvd player was it
    could it be the cables that are faulty
    i have tried everything and am thinking of sending the dvd back, i had a better picture of my limit dvd which cost me £100 and that processed ntsc prog scan.
    any help would be appreciated
  10. Foot&Mouth
    Foot&Mouth
    i take it you are using component as a connection, as a scart wont carry a progressive signal
  11. PAUL RODGERS
    PAUL RODGERS
    Sep 14, 2003
    159
    manchester
    YES
    I HAVE JUST CHANGED THE CABLES AND I NOW CAN RECEIVE NTSC PROG SCAN BUT PAL SEEMS JUMPY. THE SCREEN CAN ACCEPT PAL PROG BECAUSE L&G NOTIFIED ME THAT IT COULD
  12. JUS
    JUS
    Jan 21, 2003
    3,421
    Plute
    +317
    Paul, STOP SHOUTING You're giving me a headache:)....you will find your caps lock on the left just above your shift key :D
    sounds like the plasma isn't recognising the signal comming in. Can you manually change it to 575p?
