New power lead for xde media box
Discussion in 'Plasma TVs Forum' started by anticlaus105, Nov 7, 2005.
  1. anticlaus105
    anticlaus105
    Nov 11, 2004
    1,156
    63
    +181
    Wanted to get a right angled power lead for the xde media box.
    Site isn't working right now but was looking at www.Maplin.co.uk and product PU49D (right angled IEC mains lead)
    It has a 5amp fuse which I guess I would need to change to a 13amp like the media box plug.
    My problem is it says it is rated to 6A 250Vac. Would this be ok?
    Anyone with electrcal knowledge please help cos I don't have a clue.
    Cheers.
  2. skibum
    skibum
    Nov 1, 2005
    50
    +77
    seeing the display is only using 344 watts, it only needs a 2amp fuse. So a 3amp will be more than enough.
    The fact the media box has a 13amp is in theory a bad thing as it means it won't blow should the box suddenly draw 3500watts. It should have a 3amp at most.
  3. anticlaus105
    anticlaus105
    Nov 11, 2004
    1,156
    63
    +181
    Just double checked in case I had used TV lead for media box or something and both are 13A. Even opened the fuses out to check.
