New player
Discussion in 'Blu-ray & DVD Players & Recorders' started by grumpyguy, Jan 17, 2003.
  1. grumpyguy
    grumpyguy
    May 11, 2002
    251
    +9
    I am on the look out for a new dvd player. The 963 is on the shortlist, along with the denon 3800 and the arcam dv88+. But a newby is just around the corner in the shape of the arcam dv89. Do you reckon its worth the wait, or which on my short list is the best.
    I want a good picture, possible upgradability(not essential), and a player that will last for many years.
    Any advice
    See the arcam at http://www.homecinemachoice.com/new...emachoice.com/cgi-bin/displaynews.php?id=2798
    Thanks for the advice:)
  2. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Hi -
    You can buy the DV88 Plus now with confidence, because you can upgrade it later to DV89 spec for the difference in retail price between the two models. We expect this to be a dealer fit.
    BTW, there are new reviews of the 88 Plus in the current February issues of Hi Fi News and What Hi-Fi?
    HTH.
    John Dawson (Arcam)
