New player with DVD Audio
Discussion in 'Blu-ray & DVD Players & Recorders' started by The_kUrGaN, Dec 29, 2003.
  1. The_kUrGaN
    The_kUrGaN
    Nov 29, 2003
    373
    +16
    I watch loads of DVD's and think it's time to upgrade my existing player. I have bought a couple of DVD audio discs in the past and would therefore like to buy a unit that can cope with DVD A, as well as DVD R/RW and MP3/ JPG etc. Anyone recommend something that preferably won't break the bank? Cheers :smashin:
  2. cliveg
    cliveg
    Nov 8, 2002
    329
    Hampshire
    +8
    Hiya,
    I've just bought the Pioneer 565A player...it'll play both DVD-A and SACD through 6 phonos on the back. I guess your amp supports this format?
    www.techtronics.com have it for £199...retail is £250
    Cheers,
    CliveG
  3. The_kUrGaN
    The_kUrGaN
    Nov 29, 2003
    373
    +16
    :zonked:
    Ahem....that's something I hadn't considered. So my amp needs to be able to cope with DVD A as well as the DVD player huh?Doh! Is this just a matter of appropriate inputs or actually ability to decode? It's something I haven't seen on the Amp specs in my price range. Is this a pretty common feature or do u really need to search out the amps that can cope with this?
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,130
    Rainham Essex
    +2,392
    Your amp will not decode the DVD-A (unless you have the latest Pioneer amp & DVD connected via Firewire), that is all done by the DVD player and is then sent to the amp via 6 analogue phono leads.
    To be able to get the best from the DVD-A disks you will therefore need an AV receiver/amp that has a 6 channel analogue input. This is fairly common, but not on all amps.
    If your AV amp does not have these inputs (or you are useing just a stereo HiFi amp) then you can still get a stereo output from the DVD or even Dolby Digital or DTS via coax/optical that will then be decoded by the AV amp. You do not even need a DVD-A player for these formats, but will be missing the best from the disks.
    Mark.
  5. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,105
    Portsmouth / Middle East
    +77
    Whether stereo or surround is better is a contentious point, but if you are only going to use it in stereo many dvda disc have the stereo mix recorded in an even greater resolution. 192khz as apposed to 5.1 96khz.
    Either way some discs sound great and some sound awful. (and some are even remastered from cd's!!!)
    ch
  6. mseabroo
    mseabroo
    Aug 28, 2001
    376
    28
    Sussex
    +41
    The 565 can also be found a little cheaper at richer sounds or sevenoaks in region 2 form. £174 vs £179 respectively.
    But it's easy to upgrade to multi region if you have a learning remote (search the forums for pioneer region free, or PM me for the code).
  7. acucobol
    acucobol
    Sep 7, 2003
    62
    Toshiba 530 has dvd-a. have not tried it out myslef yet, but looking for Flaming Lips DVD-A disc to try it out.
