New Player advice needed.
Discussion in 'Blu-ray & DVD Players & Recorders' started by welshpaul, Jan 1, 2004.
  1. welshpaul
    welshpaul
    Mar 2, 2003
    254
    Currently have a Tosh 100se which i am happy with the performance but the multi region on it does not handle RCE discs.
    Wish to upgrade to an RCE compatible player but don't wish to spend a lot, only requirement that it is of at least the same standard as my present player.
    My questions are - Can anyone reccomend a player?
    Do the multi region players advertised by Richer Sounds also handle RCE discs?
    And finally i have sky+ so was considering a DVD recorder, possibly Panasonic E50, any thoughts?
  2. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    According to techtronics, the multi-region Toshiba 220e (£80) can play RCE disks...
    Yeah a mate on another forum has confirmed this, off the shelf (i.e no mods) it plays RCE disks no problem :)
