New plasma sky digital help please
Discussion in 'Plasma TVs' started by tcp/ip, Jul 18, 2004.
  1. tcp/ip
    tcp/ip
    Jul 17, 2004
    232
    +33
    Please somebody help. I bought a plasma and i have the dvd working perfectly and the picture is amazing. But no picture from my sky digital. The only connection availiable to me is an Svideo on the plasma and i orgianally tried to use a cable that has a scart lead connector on one end and an svideo connector on the other but alas no joy at all. So went to maplin and bought an RGB to S-Video converter (picture attached) but no instead of no signal coming up on the plasma i dont get that message but there is still no picture at all. Please help me people. I have a orginal Sky digital pace box that only has the two scart outputs. Is there any digiboxes that have an svideo out put. By the way the plasma is a panasonic TH-42PW5
    thanks
  2. Dr Downey
    Dr Downey
    Jan 12, 2004
    122
    19
    Cheltenham
    Is the output of the sky box set to RGB instead of PAL?
    Services - System Setup - Picture Settings - Output
    Rich
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    And make sure you are plugged into the TV scart, VCR scart is always composite. Come across that one every day...
  4. tcp/ip
    tcp/ip
    Jul 17, 2004
    232
    +33
    All sorted it was conected to the tv output so that was not the problem. The digibox was set to pal all i needed was to set it to RGB and all sorted.
    Guys thanks a million for your replys you are the best
