New plasma - need help !
Discussion in 'Plasma TVs Forum' started by manc, Jun 28, 2003.
  1. manc
    manc
    Apr 3, 2003
    151
    19
    After doing a fair bit of research i decided to purchase a hitachi 42pma400e plasma screen and it arrived this week.
    I am using a JS rgb scart - component converter with half-decent cabling.
    Sky Digital is working fine, a bit blocky but i expected that due to the signal broadcast quality but when plugged into my Sony ns 905vp DVD player the display only works for a few seconds at a time before i get a blank screen and an "out of frequency" message.
    I have enabled RGB mode on all sources and am not using any kind of scart splitter as yet, just single inputs.
    The dvd player works fine straight to the svideo input but pq is nowhere near the component quality (even if it only last for a few seconds :) )
    Any help much appreciated.
  2. manc
    manc
    Apr 3, 2003
    151
    19
    Hmm, after a bit of playing i found there is no problem on my lord of the rings dvd and all vcds so its some kind ofdisk problem.
    All my dvds are bought in the UK and are the same region :(
