New Pioneers - retention problems?
Discussion in 'Plasma TVs Forum' started by Kopacabana, Mar 15, 2006.
  1. Kopacabana
    Kopacabana
    Aug 18, 2005
    529
    +7
    I have researched the subject on this forum.
    Just to put final pieces of the puzzle together, it would appear that recent builds of the XDE and FDE (Dec '05 onwards) and the new SXE and RXE suffer little or no retention problems. Am I right in my conclusion?
  2. Attu
    Attu
    Jun 16, 2003
    809
    28
    +42
    Ive got a Dec build XDE and get very little retention, if CBeebies has been on for hours you can see the channel logo some times when you turn onto a channel with a light back ground but after a matter of seconds its gone.
    Andy
  3. dazmd
    dazmd
    Jan 13, 2006
    214
    +4
    Mine's a Feb build and was run at lower settings for 200hours,now running with higher settings and not once have i noticed any retention.
  4. Reefon
    Reefon
    Also have a Dec build XDE... 400+ hours, and cant fault the screen in any way! :smashin:
  5. keefers
    keefers
    Nov 6, 2003
    337
    Warwick
    +12
    I have a January build of 436XDE. Ran it at recommended settings for 200 hours then ramped it up to my liking.
    Haven't seen even a second of retention & I watch Sky News for hours.
    Recommended settings for reference (Thanks to OP):
    Contrast 20
    Brightness -5
    Colour -10 (Should really stay like that)
    Power Save onto "Save 2"
    K.
  6. loudhouse
    loudhouse
    Mar 12, 2002
    49
    I have a November Build and had an engineer change my Voltage settings.
    I have played my XBOX360 for many hours at a time and have had NO issues with burn in or image retention at all.
    Pioneer said everyone shoould have there Voltage settings changed to stop these issues on your screen.
  7. jwramsay
    jwramsay
    Sep 7, 2004
    1,638
    West of Scotland
    +74
    My Pioneer repair mate was at the Pioneer factory for a visit yesterday, along with other Pio repair engineers.
    Someone brought up this subject with the quip "there's a burning issue we need to talk about". :clap: :clap:
    Seems like only the 436 is affected and not the 506. This concurs with the fact that the s/w update is for the 436 only (I've had it done and it does improve matters).
    There has been NO confirmed case of screen burn. The worst Pio have seen was one which had XBOX 360 graphics on it, but it it did fade away.
    Apparently they output 1400 screens a day and have a backlog now. This factory in England supplies all of Europe.
  8. fat dog
    fat dog
    Oct 23, 2005
    72
    +6
    I bought my 436 at the end of October so guess it'll either be a Sept. or Nov. build (it's on the wall so can't check). I'm now suffering terrible retention, even with low settings. Have still got the score bar from watching Barcelona-Chelsea over a weekago! The screen buzzes unacceptably and the fan on the media box has now got louder to the point it is extremely distracting. Not exactly too happy at the moment...
  9. the slug
    the slug
    Jan 27, 2006
    23
    3
    As i posted on here already, ours is December 05 build, 201hrs06mins ran so far no issues with retension, also calibrated to similar setting as most on here ;) Top PQ
  10. Dalry
    Dalry
    What settings did you use. I would like to set my new 436 sxe.
  11. Plastic Sith
    Plastic Sith
    Jun 17, 2006
    93
    Manchester
    +27
    Recently purchased 436 XDE (April 06 build) and despite taking all the advice on these forums into consideration as regards settings etc today encountered my first case of image retention. I am now the proud ;) owner of the Czech Republic versus Ghana scoreline with associated ITV logo!!!! It seems I won't be able to watch the World Cup on the set anymore unless I want to preserve the scorelines for posterity!:eek: Am whacking on "the snow" tonight so hopefully this will sort things out.
    Can it really be the case that in order to use these sophisticated pieces of cutting edge technology to undertake that highly technical past time of "watching television" we will all have to resort to switching channels if there is a logo, take as our motto "Darker is safer" and generally spend more time concerning ourselves with what our chosen programme/input is doing to our screen rather than what it is doing to our minds!?:eek:
    Seriously Pioneer, how do you get away with it? (I believe the answer is, we continue to buy from you!)
    Of course what makes the whole thing so bad is that the set looks so gorgeous when you can actually tear yourself away from checking out yet another suspect after-image!
    Curse you Pioneer, curse you!
