new pioneer vsx 1018 -video conversion ?
Discussion in 'AV Receivers & Amplifiers' started by cairnx, Jan 12, 2008.
Tags:
  1. cairnx
    cairnx
    Dec 31, 2007
    88
    devon
    +5
    Hi guys,
    Probably a stupid question (often the best ones are!) - the new pioneer just announced is described as having "video conversion" ....... does this mean it converts analogue signals to digital ones ? ( component conversion to hdmi ?)
    Hoping to run all sources into new receiver (component and hdmi), then just run hdmi to Projector.
    Any pointers please
    thanks in advance
  2. davepuma
    davepuma
    Jun 24, 2004
    17,536
    +3,506
    Yes, it looks like the VSX1018 will upconvert all sources to HDMI and also upscale to 1080p.
  3. cairnx
    cairnx
    Dec 31, 2007
    88
    devon
    +5
    sounds great for my upgrade - thanks Dave .
    Does it work the other way around as well ? ( i.e will it convert HDMI signals to component?) current PJ doesn`t have HDMI (SIM HT300+), only Component .
  4. marty2005
    marty2005
    Jul 22, 2005
    3,694
    Great Yarmouth
    +155
    You won't get hdmi thru component because of copy protection. (hdcp)
    Sounds like a good av-amp.
    Most amps have 9 outputs so you can switch A/B. Pioneer only have 7, hopefully fixed on the new 1018.
    Hopefully it'll have a graphics osd instead of text osd.
  5. cairnx
    cairnx
    Dec 31, 2007
    88
    devon
    +5
    thanks marty , thought that may be the case
  6. gychang
    gychang
    Aug 7, 2008
    3
    I have older version of regular DVD (Pioneer Elite DV-37). With this new receiver, if I connect to HDMI Plasma TV (samsung 1018 capable), will the video be better than the "regular" DVD? I am rather new at this and hopefully understandable question.
    gychang
  7. Sheepdisease
    Sheepdisease
    Jan 26, 2009
    314
    +5
    Will someone please answer the above question?
  8. Dankeech
    Dankeech
    Feb 1, 2005
    3,637
    Stevenage, Herts
    +299
    If you mean - can you connect your DVD player to your receiver via a normal connection and then the receiver output via HDMI?
    ...then no. You can't take something and improve it like that, unless your receiver upscales non-HD signal to HD signal, and converts it to HDMI and sends to your TV via HDMI and does a better job than the TV's built in upscaler.
    Effectively about a 99% no, despite me not being familiar with your kit - sorry.
  9. Jed C
    Jed C
    Dec 5, 2008
    383
    +15
    Yes it does upconvert but doesnt upscale. :smashin:
