New Pioneer Pdp-505xde
Discussion in 'Plasma TVs Forum' started by tonyw, Sep 23, 2005.
  1. tonyw
    tonyw
    Jul 11, 2005
    11
    :lease: NEED SOME HELP, Have just taken delivery of my pioneer 505XDE and will be installing it over the weekend could any one suggest any calibration settings to get the best possible picture straight out of the box, it'll be connected primarily to a SKY box (not SKY+) and bog standard DVD player for the time being, using scart connections..any help would be greatly appreciated as i'm a novice with plasma screens etc.
    many thanks :smashin:
  2. ikon66
    ikon66
    Mar 22, 2005
    451
    Tyne & Wear
    +5
    these were mine for the 435 xde, i am very impressed with mine
    baring in mind you can have different pq settings on inputs and tuner.
    contrast +35 (really quite high, hadn't realised but it must be my prefered pic setting) prolly best less than 25 for first 200 hours
    brightness +4
    colour -4
    tint 0
    sharpness +4
    Pro Adjust menu
    Pure cinema standard
    CTI on (dunno what that is)
    all others set to mid
    Sky+ is set to rgb on input 1 with an ixsos lead not the best but a good quality. I honestly believe it's mainly to do with the signal strength and quality mine are both very good for sky and terestial
    hope this helps good luck
  3. tonyw
    tonyw
    Jul 11, 2005
    11
    many thanks for the tips no doubt i'll be posting more questions when it's up and running.....cheers
