New Pioneer: PDP-42RXE ?
Discussion in 'Plasma TVs Forum' started by MichielO, Nov 7, 2005.
  1. MichielO
    MichielO
    Nov 7, 2005
    75
    Hello,
    Here in The Netherlands the Media Markt (electronics store/chain) is now advertizing with a PIONEER PDP-42RXE plasma screen. I have never heard of that model; does anyone at the forum know it? All I can find at Google are Italian sites. It seems like a special model; even Pioneer-sites do not mention this type. 42 inch is also odd for Pioneer, since normally they have 43 inch. And it has TV and speakers built-in. I also wonder whether it uses a new-generation plasma panel?
    Regards,
    Michiel
  2. athina
    athina
    Here's a picture of it...and translated details :
    Price around 2950 euros in IT
    QUALITATIVE DESCRIPTION
    Pioneer PDP-42RXE
    Widened your experience of entertainment visual with the new television set to the plasma HD-ready endowed Pioneer of incorporated analogic sintonizzatore TV.
    This television set to the plasma is predisposed for the HD: it is in a position to visualizing it marks them to high de. nizione of the transmissions HDTV, of the Blu-ray discs, DVD HD and the fillmati ones to high definition it realizes with digital video cameras them to you.
    The integrated diffusers and the support from table are in equipment with the television set.
    TECHNICAL DETAILED LISTS
    Inches 42
    Format 16:9
    Resolution 1024 x 768
    Progressive panel XGA
    HD Ready
    Sound
    Power 2 x 10W
    SRS TruSurround XT
    System of reception
    Sintonizzatore 1
    Reception PAL SECAM
    Memorizzabili channels 99
    Functions
    Multilingual Menu OSD
    Televideo
    Modality Dual Screen (PaP)
    Modality Picture-In-Picture (PiP)
    Regulation temperature of the color
    Reduction of the digital noise them
    Logons
    3 x Scart
    1 x HDMI
    1 x Income video component
    1 x Income S-Video (AV front)
    1 x Income AV RCA (AV front)
    Physical detailed lists
    Dimensions (LxAxP) 1235 x 699 x 252 milimeter with support
    Weight 40 Kg
    Accessories in equipment
    Manual customer, integrated remote control, Diffusers and support from table.
  3. bluecupra
    bluecupra
    What price is it going for?
    Jeffrey
  4. MichielO
    MichielO
    Nov 7, 2005
    75
    Price at Media Markt (Netherlands) is 3000 Euro. In Italy I see them around 2950.
    I still wonder why it is only known in Italy and Pioneer itself never mention it on their sites (Netherlands, Italy a.s.o.). And is it a new gen. panel?
  5. df1603
    df1603
    Aug 14, 2002
    345
    +13
    I was also looking at that one today. Any idea what that is?
  6. MichielO
    MichielO
    Nov 7, 2005
    75
    I have been at Media Markt and have a quick look at the plasma. The design is as beautifull as always with Pioneer plasmas. The PQ was okay, but it was a DVD-demo, so what else would you expect. The box mentioned "made in Poland", so apperently it comes from Poland. Maybe a model originally only made for Poland? I also heard from someone that it has the 5th generation panel inside, which would mean that it is not using the current (new) gen. panel. The speakers cannot be removed, the stand is included and tv-tuner is inside, so no external box.
  7. df1603
    df1603
    Aug 14, 2002
    345
    +13
    sounds like a no-go to me...
    but the price seems attractive, perhaps calling pio reps in NL would be an option to consider...(?)
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It must be based on NEC glass if it's really 42" not 43". They do the XM3 commercial panel which is kind of HD ready on a good day.
  9. MichielO
    MichielO
    Nov 7, 2005
    75
    Next to the plasma they had a special leaflet with respect to this plasma. I hereby post them, though it is in Dutch. But I think you can understand most of it (English technical language a.s.o.).
    I also heard that it might indeed be a pro-panel of Pioneer which they once started to build, but never became a success.
  10. df1603
    df1603
    Aug 14, 2002
    345
    +13
    what does pro-panel actually mean? I wonder if it is worth taking a dive with this panel or not?
  11. mperuc
    mperuc
    May 25, 2005
    3
    It is a 436XDE with the media reciever integrated in the plasma;for those that dont want the plasma on the wall.
  12. MichielO
    MichielO
    Nov 7, 2005
    75
    How do you know it is a 436? Do not forget that the 436 is a 43 inch model and this is a 42 inch model.
  13. df1603
    df1603
    Aug 14, 2002
    345
    +13
    can some1 clearly say what kind of plasma that is and whether it is worth buying.....
  14. MichielO
    MichielO
    Nov 7, 2005
    75
    Someone told me that it is apparently a NEC-panel. Pioneer does work together with NEC, it would also explain the fact that is a 42-inch panel instead of 43-inch. The panel can be compared with a 5th gen. Pio-panel (435), so not the current/new 6th gen. (436). Maybe therefor I am not so enthusiastic with respect to the image quality.
    Pioneer has "made" this series exclusively for Media Markt (Europe's biggest electronics-chain). Today I have "visited" the plasma again and the PQ was not better than a much "cheaper" Samsung or LG, so I have decided to leave it there... ;)
  15. erlryd
    erlryd
    Apr 5, 2004
    I found a new post on hjemmekino.no that pretty much confirms what’s been said earlier. Although apparently this model will also be sold in Norway, even though there are no Media Markt stores here.
    http://www.hjemmekino.no/database/tvinfo.aspx?katalognr=225
    Quick translation (by me): “Pioneer PDP-42RXE is a new, inexpensive HD-ready plasma. The model is a result of Pioneer’s purchase of NEC’s plasma division and consists of a NEC plasma panel with good picture qualities. The TV has 3 SCART, 1 component and one HDMI sockets. Complete specs on the bottom of the page.”
    Hamsterburger:)
  16. arcamfan
    arcamfan
    Aug 16, 2005
    26
    only 1 HDMI :thumbsdow
