New Photo Gallery help ?
Discussion in 'Playstation Forums' started by kingkarl, Feb 6, 2009.
  1. kingkarl
    kingkarl
    May 20, 2004
    3,897
    +2,262
    Can anyone help me with this new photo gallery software with the 2.60 update.
    I got jpegs on my flash memory stick and when I goto copy it ask to insert media , it then sees my flash memory stick , I select it but it says no images to display :confused:
    Strange as if I just goto photo on the xmb and then select my flash drive it displays the photos without a problem.
    How do I get this photo gallery to see my pictures ?
    Karl:confused:
  2. them00ch
    them00ch
    Jan 11, 2009
    15
    Try pressing the triangle button, and selecting "show all". From memory, I think thats what I have to do on mine, but I'm not near my PS3 to double check...
    Hope this helps.
    edit:sorry I think I may have misread your question - are you trying to do it in the gallery program itself? I just copied them to the HDD from the XMB, and they showed up fine in the actual gallery app.
  3. kingkarl
    kingkarl
    May 20, 2004
    3,897
    +2,262
    The triangle button just brings up the photo gallery help bar :confused:
    Does anyone know how to get this new software to see the pictures on my usb memory stick :confused:
  4. Jack-Deth
    Jack-Deth
    Sep 25, 2003
    6,354
    Ireland
    +1,341
    Don't you need to put them on the XMB under Pictures first?
  5. kingkarl
    kingkarl
    May 20, 2004
    3,897
    +2,262
    Maybe , its confusing really.............. the photo gallery software as got the copy function built in , when you select copy it asks you to insert media i.e memory stick and then it surely should see the jpegs on the stick but keeps saying no images to display :confused:
  6. Jack-Deth
    Jack-Deth
    Sep 25, 2003
    6,354
    Ireland
    +1,341
    I definitely loaded mine on to the XMB first.
  7. kingkarl
    kingkarl
    May 20, 2004
    3,897
    +2,262
    Cheers Jack
    just done that mate and all is working fine , strange that the new photo gallery as the copy function but it dont work as stated :confused:
  8. Jack-Deth
    Jack-Deth
    Sep 25, 2003
    6,354
    Ireland
    +1,341
    Glad you got it sorted! I never looked at using the gallery to import pictures, never even thought about it. :D
  9. cols
    cols
    Sep 5, 2008
    3,338
    Colchester
    +517
    You probably don't have a folder structure the ps3 likes - hence the need to do the "display all" thing.
    If the folders are named and structured in a particular way the ps3 shows the pics without needing to do triangle / display all.
    It sounds like the photo gallery likes the same folder structure too.
    Can't remember what it is, PS3/PICTURES or PS3/PHOTOS or something, i don't view pics from external memory, i just copy mine all over to the xmb when my camera fills up!
  10. sjw
    sjw
    Feb 19, 2003
    1,872
    63
    +209
    I plugged my camera in (a Sony so it will have the correct structure) and I could copy from within the App and didn't need to copy them in first.
