new person needs new pc please help
M
mt_mckinlay
rite i need a new pc and i have 375 pounds i like playing games on it like age of empires 3 and fear thing like that i dont need it to be amazing at playing them but just needs to play them also i would like dual core and maybe 2 gig if this is possible and not realy noisy when it runs
i dont know much about computers and dont know if wat i am asking for is impossible or not but if it is can give suggestions and general advice and please post links to where to buy
thanks for all your help
jack
bcopping
Established Member
Do you have a current computer that you could salvage parts from such as case, psu, monitor, keyboard, mouse, hard drive & optical drive?
otherwise it will be extremely difficult to build a new system for that budget
bcopping
Established Member
I use the following sites to get my computer related stuff:
scan.co.uk
novatech.co.uk
overclockers.co.uk
there are loads of others though. but i tend to trawl scans deal of the day section, overclockers this week only section and novatech gives you cashback if you go through quidco
M
mt_mckinlay
no i use my parents pc the specs i said are just what i hoped for but if i cant get that then could you suggest something else that is in my budget
M
mt_mckinlay
also i am looki9ng for a new computer if possible because i have no experience putting computers together so i wont want a costum computer
badbob
If you want everything (including case, hard drives, psu and monitor) for that budget, sorry not a chance. You need a higher budget.
Didn't say what size screen you want, or resolution. Fear needs a pretty hefty PC.
M
mt_mckinlay
ok thats not pos then can anyone give some othere suggestions please
p.s can you also post links please
thx jack
M
mt_mckinlay
Intel Core 2 Duo Processor E6300
1.86GHz, 1066MHz FSB, 2MB Cache
Microsoft Windows Vista Premium
1GB DDR2 RAM
250GB Hard Drive
Multi-Format Dual Layer DVD RW Drive
512MB nVidia Geforce 7500LE Graphics
9-in-1 Media Card Reader
7 USB Connections
4 PCI Slots
wat about this pc do you think it would run some good games and run quietly or not
badbob
Go for larger HD (cost per GB) 500GB are value for money. Samsung drives are quiet, although vibrate a bit so mount with silicon pads or hang them with elastic.
Get 2GB, if using Vista you'll need it.
That videocard is rubbish for games.
You have option- passive, low power consumption videocard (HTPC) or air cooled, high power consmumption for games. I have a ATI X1900XT which is great for gaming but even at idle it's too loud for a HTPC.
M
mt_mckinlay
Standard Features
CPU: AMD64 Athlon X2 4200+ AM2
CPU Cooler: Standard CPU heatsink & fan
Motherboard: Asrock AM2NF6G-VSTA
Memory: 2.0GB Kingston DDR2 667mhz (2x 1GB)
Hard Drive: 400GB S-ATA2 3.0Gb/s
Optical Drive: 18x Double-Layer DVD+/-RW
Peripherals: Wireless keyboard and mouse
Monitor: 19'' Widescreen TFT Monitor
PSU: 400W PSU
Case: EZCool K110
Warranty: 3 Year Bronze Warranty
wat bout this also
thx for all your help by the way and please keep it coming
M
mt_mckinlay
Standard Features
CPU: Intel Pentium D 945
Motherboard: ECS 965T-A
Graphics card: NVidia GeForce 7300LE 512MB
PSU: 400W PSU
Case: EZCool K110
been told cant afford upgrades
M
mt_mckinlay
Standard Features
PSU: 400W PSU
Case: EZCool K110
this is the best i have found so far but do you think that it will be loud i no it hasnt got a graphics card but i have a ati radeon powercolur that i can put in it do you think i will get better than this spec or not could you suggest wat you would buy if you were getting one on this budget
M
mt_mckinlay
i can get the below model and get this graphics card is it any good
NVIDIA GeForce 7900 GS OC 256MB GDDR3 BFG
Vandiesel
Established Member
AMD Athlon 64 X2 4000+ (2.1GHz) Socket AM2 Energy Efficient L2 1MB (2x512KB) Cache Retail Boxed Processor
http://www.ebuyer.com/customer/prod...hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=125199
Corsair 2GB Kit (2x1GB) DDR2 675MHz/PC2-5400 XMS Memory Non-ECC Unbuffered CL4(4-4-4-12) Heat Spreader Lifetime Warranty
http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=98708
Antec Black NSK4480B ATX/MATX Mini Tower - With 380W EarthWatts PSU
http://www.ebuyer.com/customer/prod...hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=130948
Maxtor STM3250310AS 250GB SATAII 8MB Cache - OEM
http://www.ebuyer.com/customer/prod...hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=131214
Pioneer DVR-112DBK 18x DVD±RW Dual Layer Internal IDE (Black) - OEM
http://www.ebuyer.com/customer/prod...hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=125215
Cibox C1905 19"TFT Monitor Widescreen 1440x900 800:1 5ms VGA/DVI Silver/Black Speakers 3 Years Warranty
http://www.ebuyer.com/customer/prod...hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=119321
Xpertvision 8500GT Sonic edition 256MB 128bit DDR3 DVI TVO PCI-E
http://www.ebuyer.com/customer/prod...hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=128084
Biostar TF560 A2+
http://www.cclonline.com/product-in...ategory_id=342&manufacturer_id=0&tid=tf560a2+
Comes to around £400, add them to your basket on ebuyer
A keyboard and mouse/speakers from here for a tenner or so
http://www.ebuyer.com/summersale
£375 is pretty hard, you can get a ebuyer/other brand 19inch ws for £98- but out of stock, that is another £12 saved, and a biege dvd-rw for £14 another few quid saved, shop around on the memory another tenner to be saved there, you could bring it in on budget if you really wanted too
Amazon Fire TV Cube Gen 3 Review: Coming Soon
