New person and advice regarding 26" HDTV ready LCD's
Discussion in 'LCD & LED LCD TVs Forum' started by si@Srbpower.com, Jul 13, 2005.
Tags:
  1. si@Srbpower.com
    si@Srbpower.com
    Hello guys and gals :hiya:
    Looking for some friendly advice regarding LCD's as I know nothing :thumbsup: and I heard loads about this HDTV :eek: but its kind of gone a bit over me.
    I'm really after a 26" LCD TV and have been looking at these 2.
    http://www.acernotebooks.co.uk/Acer_AL2671W_26_Inch_Widescreen_TFT_Screen_EV.M0107.009/version.asp
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=92051
    Will these be ok with HDTV are most importanly are they any good. Looking at spending around 500-600'ish on one as I spent most of my cash doing my car :rolleyes:
    Any advice would be great, many thanks
    Si :)
  2. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    I looked at the hyandai as well but according to someone on here it is not really HD ready as it does not have any HDMI or DVI inputs
    I think I will go for the samsungLE26R41B which has had some decent reviews on here
  3. si@Srbpower.com
    si@Srbpower.com
    Thanks mate, so thats the hyandai off the list. The samsung you mentioned looks quite nice :smashin: Just had a quick look on the web, seams to get good reviews and its in my price range :smashin:
    Is it really worth going for a LCD with HDTV?
    Si :)
  4. igauk
    igauk
    Apr 8, 2005
    132
    Glasgow
    +6
    Well, if you want to watch HD broadcasts (HD Sky and DVD are imminent) then yes! Whether there will be free to air HD broadcasts within the lifetime of your TV is anyone's guess. If you don't want to pay whatever the Sky premium will be or invest in a HD DVD player then its perhaps a moot point, but HD ready LCDs tend to be newer, better specced models anyway, even if you never use the HD capability.
