New PC spoiling my TV Reception, not gonna do any permanant damage no?
B
BuyingATV
Got a new PC with a window side panel and its facing my TV and when its on it makes my tv reception bad. But if I cover the glass panel on PC case the goes back to normal. Not knowing alot about this things its not gonna do any permanant damaged to my brand new sony 28in is it? just being paranoid here but gotta check.
thanks
DVDcake
If it's just radio interferrence and not magnetic, i.e. its not putting blotchy colours all over your screen then you should be o.k. The best thing to do is seperate them as far as you possibly can, maybe in different rooms. Bet you thought all that metal a PC running into GHz is encased in was just for show.
B
BuyingATV
I just get wavey lines, and wanna know for sure since i cant seperate them since i need em in the same room, thanks
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
