Hi all im new here but ive been reading reviews on this site for a while and alot of you seem to know your stuff.
im planning to build a new pc with this config:
Samsung Series 5 True HD 32" LCD TV £638.01
OCZ 2GB DDR3 1800Mhz Dual Channel Kit £138.64 Each Ill Be Geting 2 of these for 4GB total)
Asus P5E3 Premium Intel X48 Socket 775 Motherboard £258.49
Intel Core 2 Duo E8400 3.00Ghz 1333Mhz FSB £134.61
WD RE2 160GB SATA2 16MB Hard Drive £39.94 Each (ill be getting 4 of these and running them in raid 0)
HIS ATI HD 3870XT 512MB GDDR4 £135.11 Each (ill be getting 2 of these and running them in crossfire)
LG GGC H20L BLu-Ray & HD-DVD SATA Drive £85.76
LG GH20NS10 DVD-RW SATA Drive £16.44
PC Power & Cooling Silencer 750W PSU £105.74 Each (ill be getting 2 of these to run a dual PSU system.
Adaptec 3405 4-Port SATA PCI-Express 4X 128MB Raid Card £206.87
ill be running all of this in a Lian Li PC343B Cube Case (£250.22 with all extra's that ill need)
My hard drives will be mounted in Silverstone CFP51 hard drive cages
and for cooling ill be using 8 Scythe S-FLEX 800RPM 120mm fans. all of the fans and power supplies will be mounted using rubber grommets and sound vibration dampening as silence will be of the upmost importance. (hence the 2 PSU's each psu will only be under about 50% load meaning they will run cooler and also quieter.
right now down to my question....... im looking for a good sound card for this system. i will be playing games aswell as using this pc for viewing of dvd's media files and lots of music. just to give you and idea i currently have a Sherwood Newcastle R-525 AVR. and due to space limitations i am only running in 2 channel mode and the speakers i am using are some very old Dynatron's (i love the sound of these speakers) but i am also looking to get a pair of monitor audio BR5's a pair of monitor audio BR1's and a monitor audio BR-LCR. (i will be getting a much bigger room)
im willing to spend up to £200 on a sound card. i currently have my onboard sound and i also have a sound blaster audigy 2 ZS which has served me well. do you know of any good sound cards or shall i just stick with my Audigy 2 ZS?
