New PC - 1Gb or 2Gb memory?
Discussion in 'Computer Components' started by Triggaaar, Aug 18, 2005.
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    Without going into too much detail, after an 8 month delay, I'm trying to order a new PC today - AMD Athlon 64 3500, SLi board, 6600GT, lots of HD and power etc.
    I'll be paying full price for all but the CPU, motherboard and memory, which I'll be getting a 50% discount on (company reasons).
    Therefore, I'm wondering if it's worth getting an extra gig of memory, or if I'm not going to be needing more than 1gig for years.
    The only use I thought may like extra memory was photograpy (slide shows, editing, large pics - Nik D70). Also used for games, dvd etc.
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,608
    2
    In a secret location with Jennifer Lawrence
    +9,316
    Definitely go for 2.
  3. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    If it's cheap, then get it.
  4. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    Photoshop (picture editing) will eat everything you've got and more!
    Rajiv
  5. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    1 Gig of corsair is £65 at Ebuyer, might be less elsewhere, so if you can get it for less it's a nobrainer.
  6. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    Thanks guys.
    It's not that it's any cheaper, just that I'll put it through the company - can't justify putting HDs and GC through, but can with memory (& cpu). I haven't seen anyone using 2 gig with the specs here, although I haven't looked on the forum for a while. Wasn't sure if it was useful for photos, or if 1 gig was more than enough.
    I guess I should get DDR Twin X (Asus A8N-SLI Deluxe socket 939)
    £214.44 - 2Gb (2x1GB)Corsair, DDR400, non-ECC, 2x184 DIMM, unbuffered
    vs
    £240.88 - 2Gb ( 2 x 1 Gb) Corsair TwinX, DDR, PC3200, ECC Registered
    Any suggestions?
    PS - buying from scan, along with everything else
  7. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    Missed that, thanks. 2 Gb it is.
    Am I better just getting 2Gb of cheap corsair, rather than DDR Twin X?
    Cheers guys
  8. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    Only buy ECC Registered memory if you know your motherboard and CPU support it.
    I think ECC Registered is for Opteron not Athlon, but someone else may know better.
    I would go for the TwinX. Your cpu and motherboard are Dual Channel capable. Although it does not make a vast difference speed wise it does make some and the premium is not substantial. You also have the advantage that Corsair test their memory in dual channel mode on ASUS motherboards so you know its got to work, this is especially helpful as TwinX uses agressive timings which do not work by default on all systems, and I know, I have to work them out by hand.
    Don't know how you build your computer, but I recommend and overnight burn in with memtest before you start installing anything.
    Rajiv
    Rajiv
  9. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    You can always go for 3GB, if you by from the crucial website it's cheap and free delivery and you should be able to search by your motherboard...
    www.crucial.com
  10. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    Cheers guys, 1 PC ordered.
    You were right, had to go for non ECC.
    Got 2Gb - not into loads of photoshop yet (old PC can only just view the pics), but would like to be. Still I doubt I'll use it enough to demand 3 gig.
    Thanks again for quick responses.
  11. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    Cool website, thanks. I've ordered it from Scan though, having the whole lot delivered tomorrow, so I can start building it over the weekend, before my helper disappears on holiday.
  12. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    If it was going through my company my Asus would suddenly jump from 1 to 3. Well I can dream can't I. :D
    That sounds like I have a company. If I had it would go t*** up in a week.
