New Panny Plasma TVs and Top Up TV CAMs
Discussion in 'Plasma TVs Forum' started by AOD, Jun 4, 2004.
  1. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    As the title suggests, I'm curious to know if the new swish sets with the onboard DVB tuners also have a suitable slot for a CAM (as IDTVs are supposed to) so that you could view Top Up TV by using an appropriate CAM?
  2. zAndy1
    zAndy1
    Nov 26, 2002
    22,410
    2
    5
    163
    +8,809
    They have a common interface slot, whether that means they are compatible to TUTV who knows. I don't think it's as straightforward as just having the necessary slot for the cam. I would guess it should work to be honest but couldn't say for sure.
    Andy.
  3. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    In theory it should be.
    They should be in the same boat as any other IDTV, of course as you say, whether or not it will work is another story. :)
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    T***s Up TV are still only compatible with old On digital boxes, nokia mediamaster and basic pace freeview. I wonder if they lack the funds to do more development. Having the slot is nothing to do with compatibility, apart from the obvious, physical part. There is a 'list' on their web site, that's what it says.
  5. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    In addition to these, several people have tried the CAMs with other hardware (such as IDTVs and the Netgem i-player) and it seems to work.
    I personally have the Netgem and whilst I wouldn't call it plug and play just yet, it's getting there.
    Just wondering what my best option would be PQ wise, the other half wants a plasma in the bedroom but is adamant that there should be no cables/boxes on show.
    Personally I'd plump for a HD Plasma monitor and feed it via component from the Netgem, but then we'd need speakers etc for basic stereo listening, unless we go for something like a Viera.
    Only prob is I'm not sure that our plasterboard walls would take 41kg of screen + mount.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Put up properly it will be fine we have 60Kg+ of plasma on a stud wall.
  7. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    Thanks, that's good to know.
    I still think I might entrust it to a professional though, my destroy it yourself skills aren't exactly finely honed. ;)
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    "we" are proffesionals mate!
  9. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    Just as well, cos I'm not. :)
    At least not where AV or DIY is concerned.
