New Panny 42PT10 , help req
Discussion in 'General TV Discussions Forum' started by Dunny, Mar 14, 2002.
  1. Dunny
    Dunny
    i'm getting the panasonic 42pt10 delivered on saturday,
    being a bit wet behind the ears on RP sets can you guys give any advice about what to get the delivery dudes to
    set up picture wise
    i'll be ok connecting up me av equipment but after reading posts about
    CONVERGANCE ??? etc
    any help would be appreciated.
  2. laurel
    laurel
    Hey Dunny
    Good choice (IMO).
    Do a search on TX42PT10 here and you will find a number of posts (some by myself) dealing with setup etc.
    I would suggest you don't get the delivery guys to do anything other than put it where you want it.
    Firstly, don't worry too much about convergence at this stage.
    I would suggest you:
    1. Plug everything in.
    2. Go through the auto setup.
    3. Adjust the channel assignments as you want them.
    4. Adjust contrast/brightness to between 40-50% (depending on your preference).
    5. Watch and enjoy.
    After a while you might want to mess around with the convergence, but do a bit of reading here first and do the search I mentioned.
    Happy viewing!! You will not be dissapointed.
    Let us know how you get on.
    What other kit do you have??
    Laurel
