new panasonice55 user setup probs
Discussion in 'Blu-ray & DVD Players & Recorders' started by jaggyben, Mar 9, 2005.
  1. jaggyben
    jaggyben
    Mar 9, 2005
    5
    i purchased my panasonic last week managing to record with it ok i have apanasonic quintriix tv with Q LINK and should be able to record direct from tv comes up no signal or tv off can anybody tell me where im going wrong and tell me best way to wire up tv dvd recorder and sky as booklet a bit confusing yours not so clever newbie :lease:
  2. kinginter
    kinginter
    I use 2 scart leads. One goes from AV1 on the (TV) to AV1 on the (e55) then the other scart lead goes out of AV2 on the (e55) to (VCR scart) on my Sky digibox. Then when I want to record anything, I always record from Sky - Channel AV2 on (E55)
    Hope this helps
  3. jaggyben
    jaggyben
    Mar 9, 2005
    5
    thanks kinginter for your help i have a quiet afternoon planned will try out your advice
  4. avio
    avio
    I've also got an E55 and a Panasonic DTX40 and the Q-link works fine but as far as I know it will only work using the tellys built-in receiver using Q-link.
    My tellys AV2 (only scart with Q-link) goes to AV1 of recorder and AV2 of recorder is connected to digibox.
