new panasonic home cinema
rooney
any one got any info on the new panasonic all in one scht870
rooney
i also looked at this http://www.avland.co.uk/panasonic/scht870/scht870.htm
think it must be a misprint about the dvd recorder bit
1000 wats
dvd recorder
smart looking speakers
to good to be true
i have beeen looking everywhere on the web for info on this system not sure if its new old etc any one who works at panansonic whos on the forums with any answers. if it is a new model then ile probly wait till it comes out cant be doin with sepaprates to much grief and the wife moans to many boxes(joys of hasle free technology)
gringottsdirect
1000 wats
i have beeen looking everywhere on the web for info on this system not sure if its new....
SC-HT870 is brand new.
RMS Total Power 1000w
Front 170w x 2 ( 1khz, 6 Ohms, 10% THD ) RMS
Centre 260w ( 1khz, 4 Ohms, 10% THD ) RMS
Surround 70w x2 ( 1khz, 4 Ohms, 10% THD ) RMS
Subwoofer 260w ( 100hz, 4 Ohms, 10% THD ) RMS
DIN Total Power 750w
Front 140w x 2 ( 1khz, 6 Ohms, 1% THD )
Centre 180w ( 1khz, 4 Ohms, 1% THD )
Surround 55w x 2 ( 1khz, 4 Ohms, 1% THD )
Subwoofer 180w ( 100hz, 4 Ohms, 1% THD )
THD means Transient Harmonic Distortion, it sounds nasty so ten per cent of it will be unpleasant. One per cent is more tolerable but you'll still turn it down to lower levels to achieve optimum performance.
On paper this system looks like it will play really loud, in practice, the inefficient small drive unit speakers supplied will soak up a lot of power without turning it to sound. Don't expect it to be THAT loud. Having said that the output is higher than most all-in-ones and the sound quality may be quite decent.
Separates could be assembled for the same money with better performance but may not suit your other requirements. :cool:
rooney
wich separates would you recomend i am just about to buy new pany plasma TH-42PE30B thought that the all in one would match
thanks for the above info
rozzar
there isn't even Dolby Digital EX on that. Surely all channels should get the same power too, for an even spread of sound (possible exception of the sub)
Panasonic HT systems can EASILY be beaten by even the likes of Pioneer all-in-ones let alone true separates systems
rooney
they probably can be beaten or out performed but for 400 quid dvd player amp and speaker package sounds prety good to me there is nothing else for that sort of price that comes close (if there is let me now) the pioneer dvs990 is about 400 wats of music for the same price of the panasonic wich is 700 guess ile have to wait till its available to find out if its anything like its predecesor scht900 then it should be ok
rooney
spoke to panasonic the system will be out in june and is suposed to match the new panny plasmas (about to get mine 42pe30 happy days)42pe30 50pe30 etc still reckon it might be a bargain
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
