New Pana E50 - confirmation needed
Discussion in 'Blu-ray & DVD Players & Recorders' started by ABBITEA, Dec 21, 2003.
  1. ABBITEA
    ABBITEA
    Dear All,
    Having read a number of excellent posts I would welcome confirmation that I am about to set my system up right.
    I have a Hitachi plasma 42pd3000 which has 3 scart inputs ( 2 & 3 being RGB) & component inputs.
    Setup
    SkY+ to plasma AV2 via scart using RGB
    Sky+ optical out to Sony Dav 550
    Sony Dav 550 to plasma Component
    Sky + VCR out to E50 AV2 scart
    E50 AV1 to plasma AV3 via scart using RGB
    I am using the Sony Dvd for all my films. The Pana is to be used for backing up stuff I want to keep after being recorded on Sky+
    Is this the right way for best picture quality?
    Have I missed anything?
    Do I need to do anything clever in the Sky+ set up or the Pana setup?
    Thanks for any help
    Abbi
  2. jem
    jem
    Sep 24, 2002
    527
    +7
    This will mean that you are recording in Composite video and not RGB - not good.
    You need to do this;
    Sky+ TV out to E50 AV2
    E50 AV1 to TV AV3
    Set the E50 AV1 to RGB, AV2 input to RGB and AV2 connection to Normal.
    Sky+ will pass through the E50 in RGB and will record in RGB. Your only problem will arise if you record the terrestial channels and wish to watch Sky at the same time. If this is the case you will need to connect the Sky+ VCR out to your TV but it will only be composite video. If you have any S-Video inputs on your TV you could use the S-Video out from the Sky+ box to the TV - Sky+ will output both RGB and S-Video at the same time.
  3. ABBITEA
    ABBITEA
    Thanks for that.
    From what you are saying I am guessing that the video out scart on the sky+ box is not RGB. Hence the reason for using a pass through.
    As regards terrestial Tv I have do not have a normal ariel just the sky dish so no problems there.
    Just 1 question I guess I can connect the E50 AV1 to either Av2 or Av3 on the plasma?
    Thanks again
    Abbi
  4. jem
    jem
    Sep 24, 2002
    527
    +7
    Yes exactly right.
    Yes.
