New Pan... HD500,no probs..:)..now no pic!
Discussion in 'Plasma TVs Forum' started by aubigne, Jun 6, 2005.
  1. aubigne
    aubigne
    Hi guys, my first post, just got my new 500, set up perfectly, worked fine for first hour, then began to drop pic occasionally, sound ok, then no picture at all.
    Have re-connected scart leads in various set ups but no effect.
    When I change input mode nothing happens either.
    When you turn it on again, initially there is a pic then it disappears within 30 secs, suggestions?
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
    cry.... :suicide:
  3. aubigne
    aubigne
    Crying was an option, thanks for your useful input mal.............now its back on again, occassional flicker, drops out...none the wiser.......any other thoughts?
  4. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +141
    If it's happening on all inputs then it sounds like time to call the shop that supplied the TV &/or Panasonic and make use of the warranty.
    Hope you get it sorted soon.
    S.
  5. greyhorse
    greyhorse
    Apr 16, 2005
    445
    restore to factory settings ??? then try again and unplug everything.
  6. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
    Anytime... :thumbsup:
  7. aubigne
    aubigne
    This appears to be a temperamental one.....now everything is fine again...........will keep you all informed....................just the very odd.......dropped blank screen.
  8. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,537
    London
    +467
    very odd ? is this on Freeview only or all inputs ? best thing is to swap it out and nip the problem in the bud.
  9. aubigne
    aubigne
    You mean get back to seller and ask for replacement or swop scarts, etc around?
    It was on all inputs, might be down to my odd set up though....don't ask!
  10. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,537
    London
    +467
    If you've got an odd set up then it might be worth spending time to make sure you haven't missed something. Though droping frames or intermittent blank screen isn't a symptom of that kind of problem *usuallly*
    Get back to seller ASAP and swap it for new replacement otherwise.
  11. aubigne
    aubigne
    Ekko Star, thanks for that, I have e-mailed them just now and hopefully get it sorted, pity as I am in N Ireland and they are on mainland!
  12. aubigne
    aubigne
    back to its old tricks.............:(....no image on screen no matter what input/button you press.
  13. aubigne
    aubigne
    Not sure whats going on, but it has behaved impeccably all day!
  14. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,818
    71
    birkenhead
    +74
    if i was you mate just to be on the safe side i would ask for a new set,besides that i did the same thing as you our doing now and got stung big time when my tv develloped a serious fault 6 weeks after the initial problem first surfaced 2 weeks after my purchasing it.
  15. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    Just ask then to give you another new telly. don't settle for anything less!
    Its so frustrating when you spend 2k plus on a dream tv, then it decides it want to get moody!
    I am getting mine tommorow. touch wood.
  16. aubigne
    aubigne
    further up-date.....................no problems since, but I have informed the guys I bought it from so they are aware........hold on to it for now......thanks guys
