New Owner Seeking help and advice
Discussion in 'Plasma TVs Forum' started by neil20v, Nov 12, 2004.
  1. neil20v
    neil20v
    Hi Guys
    I just purchased a Thomson 42WB02SU plasma display from Curry's, it came with a seperate tuner box and some basic cables.
    I wasn't really in the market for a plasma screen but went in looking to buy a 32" Sony CRT TV, this Tv was in the sale and i managed to negotiate an amazing deal on the price.
    The Picture quality in the shop looked great. I have since got the TV home and fitted on the wall bracket that i purchased at same time. It looks awesome on the wall :smoke:
    I have the following equipment to connect:
    Denon DHT500SD Home cinema system
    Sky Digital
    X-Box console (Picture and colour qulaity on this is very poor )
    I have connected up the DVD player using some basic cables that the shop gave me but the picture quality isn't as good as when i viewed it in the shop.
    I want to improve the picture quality but i'm unsure as to what cables are best, any suggestions that anyone can give would be greately appreciated.
    The TV came with a seperate tuner box as the screen only accepts DVi and PC inputs. Is it worth me upgrading the tuner box as it only has scart inputs and looks a bit basic.
    The picture on some films is grainy and pixalated :(
    Any help or advice would be much appreciated :lease:
    Regards
    Neil
  2. neil20v
    neil20v
    I was considering getting the AverMedia TV Box 9 from www.rs100.co.uk do you think this will improve picture quality on the screen and when my x-box is connected.
  3. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    1st port of call i would get some1 out from currys and to let them now u not happy and to test the set
  4. neil20v
    neil20v
    I am happy with the set its just that they must of been using different cables as the picture was clearer.
    I was just wondering if i was to buy better quality cables and a better quality tuner box if that would improve the picture.
    I have read a lot of places that cables can make a big difference to the picture.
  5. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    find out what cables /feed /dvd /settings etc they used in the shop if u then get the same u should get the same pic quality
  6. neil20v
    neil20v
    I will contact curry's and try and find our what cables they used when conencting it.
    do you think the AverMedia TV Box 9 will improve things even more over the standard Thomson external tuning box.
    Any ideas how i can get a better picture on the x-box?
