New Onkyo 605 - Help Needed
R
RD8477
I was hoping that someone can help me with a few questions regarding the 605 I got recently.
Firstly this is my first av receiver. I am planning on buying a set of 5.1 speakers at the end of January and currently have the receiver connected to an old set of 5.1 Limit speakers and sub. I know these are not the best but it's all I've got for now. The first problem is I don't think I have configured the OHM setting properly as I don't know what the rating is for the speakers as I can't find the manual and cannot get any info on the web for these. I purchased them from Richer Sounds over 6 years ago. Question is will this damage the receiver if it is not correct?
Secondly when I play a game on my 360 and have the AV setting on Game - Dolby Digital, the speech is very faint and can hardly hear any dialogue from the game. When I switch it to Stereo everything is fine but obviously not getting 5.1 sound from the speakers. I also have a problem when I watching tv on my freeview box. I have connected the box to the receiver via the composite leads. I know this isn't ideal for the best sound but I keep getting a "tinny" sound when the receiver is set at either NEO:6 Cinema or PL11 Movie. Any ideas why as when I select stereo all channels etc is sounds ok.
Lastly the 605 seems to heat up really badly. I was told by a guy at Richers Sounds that they do run quite hot and that there is a safety cut off if it gets too hot. That's all well however I'm still concerned at how hot it gets. Not sure if this is happening because I haven't configured something correctly.
Any help at all will be greatly appreciated :lease:
B
Babbler
Cant help with the sound really but I know that it does get exceedingly hot. I have mine with 2 inches above it and no backing/front to the cabinet.
Its the one downside (do a search for onkyo 605 hot or heat on google to see this!).
R
RD8477
Thanks for the info. I did google it and there seems to be loads of people having the same problem. As long as there is a safety cut off then I suppose it should be fine. Just wasnt sure if it was the OHM setting that was causing it.
R
RD8477
Ok I've sorted out the problem I had with the speakers. My bad. School boy error
DenzilTK421
What was it then - others may learn from you?
I was going to say that the speech comes from the center speaker only. I thought I'd somehow managed to get rid of the annoying commentators on Tiger Woods golf, only to find the center speaker was disconnected.
R
RD8477
LOL yeah same issue as you. Didn't say initially as I was actually embarrased with myself :oops:
googlebox99
Mine doesn't seem to get as hot as everyone has been making out. I just got it, wondering if they have changed something internally. It gets warm, but the PS3 runs far hotter.
R
RD8477
I've got a PS3 too and if it ran as hot as my Onkyo I would have a panic attack!! Mainly because I got the PS3 in Singapore and if it broke then I'm in big trouble
