New nVidia drivers 77.79 for MCE available
D
Deleted member 39241
I don't suppose this addresses roll up 2 and live tv judder with the purevideo codec?
TheCrow
Not used rollup 2 myself but it does say "Support for Windows XP Media Center Edition 2005 Update 2" on nVidias Release Highlights
evolution400
Established Member
Corrent me if I am wrong but the nvidia codec is totally seperate from the nvidai gcard drivers as windvd codec works fine with rollup 2.
cheers.
TheCrow
cheers.
Hi Evolution400,
Can I ask which version of windvd are you using with MCE?
I have tried 6 and 7 and both give me transport problems with Live TV.
D
cheers.
I wouldn't say you were wrong, but as the software and hardware components have an intrinsical inter-relationship, I would not call them totally separate.... :)
evolution400
Established Member
lisa
Well if the Windvd codec works and the nvidia codec doesnt that indicates to me that they are seperate. If your thinking of the pure video technology this is a combination of the codec and the gcard however the software part can be disabled via unticking the box for hardware decoding or simply using another decoder such as windvd.
cheers ;)
D
cheers ;)
So it would be impossible that a change in the graphics card drivers would fix the incompatibility between nvidia dvd codec and roll up 2?
evolution400
Established Member
Yep sorry to say Lisa, if no codecs worked then I would say it would be possible.
I use this codec also even though I have an ATI card and will not upgrade until nvidia fix it because its the best IMO :)
D
Well, seeing as I had a new sound card, new nvidia drivers, and roll up 2 to install I went for a clean install (only 2 hours this time, it's getting quicker..) and my set up is working lovely with roll up 2, new nvidia driver and nvidia dvd codec.... not sure what that means, except I am happy that it all works (for the moment)!
jimbob19
Established Member
Does S3 stanby work properly with rollup 2 . I have heard on other forums that it stops S3 working properly i.e. half the time it wont come back out of S3 and record :(
D
DaveP
I just installed my new 6600 and installed the latest driver and got the juddery live TV. Change the codec to PowerDVD and it is fine.
Looks like I'll have to do a new install (yet again!)
Lisa, what order did you do the installs in? Card drivers then Purevideo Codec or vice versa?
Dave
D
Funny you should say that.... came down this morning and it was not in standby, I tried to put it in standby manually, and it went in then out again straight away... grrr :mad:
Dave
MCE, mobo drivers, sound drivers, graphics drivers, anti-virus, windows updates, rollup 2, tv card drivers, nvidia dvd codec, then all the other stuff....
evolution400
Established Member
There is a reg patch that I applied to allow USB S3 standby maybe rollup 2 has overwritten it ?
If you havent installed the reg patch then I am out of ideas.
evolution400
Established Member
lisa
Another reinstall come on then lisa tell us the total amount of times you have reinstalled your MCE pc maybe you have the forum record ?
Means as your happy with everything now why not try out ghost..............turn to the dark side you know you want to :)
D
What's the reg patch.... I don't think I had it installed, I could give it a go though..
D
evolution400 said:
Another reinstall come on then tell us the total amount of times you have reinstalled your MCE pc maybe you have the forum record ?
I was waiting for this.... however in this case as I had changed my sound card, so I wouldn't have wanted to use the ghost image with all the drivers for the onboard sound which I have now disabled... :)
evolution400
Established Member
I found the link on greenbutton it appears to be down at the moment though.
I can't recall what it does but it actually got my pc going in and out of S3 via button press on remote perfectly.
D
Ok, thanks, I will look it up later...
D
DaveP
lisa
Thanks, looks like I'm in for a busy weekend!
Dave
markxtc123
Established Member
Hi Lisa,
The Reg patch is as follows:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\usb]
"USBBIOSHACKS"=dword:00000000
"USBBIOSx"=dword:00000000
As always, back up the registry beforehand.
Mark
jimbob19
Established Member
The registry patch allows the remote to bring system out of S3 standby .
However if MCE was installed with the bios not set to S3 it will need further tweaking
You need to run a utility called dumppo.exe , this allows you to change the default standby from S1 to S3 . The instructions are perfect on a thread on thegreenbutton - but its down at the moment :(
When greenbutton is back up will post a link to the thread :)
Samsung & LG UK TV Prices 2023; Amazon Fire TV Cube; Calibration Tools of the Trade + AV news
