petrolhead
This may be old news. If so sorry and ignor.
Got a Gforce card?
Got an old Projector that you cant hang off the wall because there are so setting for trning the picture 180 degrees?
Well the new Nvidia drivers are just the ticket,
http://www.nvidia.com/view.asp?IO=winxp-2k_40.41
With these drivers you can rotate the picture 180 degrees.
Problem solved.
All you need now is some clever device to hand your projector off the ceiling
NB You MUST uninstall any old drivers first!
Got a Gforce card?
Problem solved.
