new ntl box
Discussion in 'Cable TV & Virgin Media TV' started by MACKY, Sep 23, 2005.
  1. MACKY
    MACKY
    does anybody know of a new ntl cable box for the future wich may have component video connection ? cheers macky....
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I wouldn't expect any standard digibox from NTL to offer component, they are buying to a price point hence the lack of RF passthrough and phonos for audio on some STB's.
    IF they ever get round to offering a DVR or HD STB then they will probably offer component.
    If you need component now then you can buy a RGB to Component convertor, not cheap though.
  3. MACKY
    MACKY
    Starburst ! i tried a rgb convertor from maplins at £80. It was crystal clear when it worked but it was like it wouldnt settle down and displayed bands of different colours across the screen (projector)..Macky.
