new motorised system STB
Discussion in 'Satellite TV, Sky TV & FreeSat' started by eddiewww, Jul 25, 2003.
  1. eddiewww
    eddiewww
    Nov 14, 2002
    520
    46
    Blackheath, SE London
    +176
    hi..
    a while ago i bought a Force STB and dish..it has a 5 in 1 CAM... i used it mostly for live footy and the odd "art film" ... it stopped working a while ago and it looks like the LNB is gone... I obviously need to replace it and thought i may add a second box to the system.. so me and the missues can enjoy the "art movies" without worrying about the kids wondering in !!
    I assume its fairly easy to have this set up... i was more wondering thoughts on what box and CAM are beat at the moment..
    thoughts ?
    cheers
    eddie.........
  2. Robbie34
    Robbie34
    Jul 6, 2003
    332
    Merseyside
    +11
    You really need a twin lnb if you have a second box.
    Go for a receiver with an embedded UCAS that will take a 6in1 card. I have a Sonysat - now called Nextwave since Sony objected to the use of the name - and it has been fine. There are a number of other boxes which get good reviews. Steer clear of Manhattans which have been criticised for unreliability and poor software.
  3. IvorBigun
    IvorBigun
    Have a look over on Satdudez, lots of good advice over there.
    Personally i would look at one of the Technomate range.
    Regards
    Ivor
