New Motherboard??
Discussion in 'Computer Components' started by chuckalicious, Sep 20, 2005.
  1. chuckalicious
    chuckalicious
    Sep 15, 2004
    247
    +4
    Hoping someone can help me:
    Does anyone know of any Micro ATX Socket A motherboards, which preferably have an FBS of 200 (400)Mhz with onboard sound which has a SPDIF output?
    I know it sounds like a tall order, but I'm having terrible trouble with my current sound card and am beginning to wonder if it's my motherboard, locking IRQs to PCI slots. So I think I'm better off with a mobo with a built in spdif.
    I have to be able to get it in the UK
  2. chuckalicious
    chuckalicious
    Sep 15, 2004
    247
    +4
    And I should have said, I already have the Abit-VA20 :)
  3. tinoest
    tinoest
    Aug 19, 2005
    999
    +19
    N-Force 2 Solutions are what you are looking for.
    Biostar M7NCG 400
    GIGABYTE 7VM400M-RZ
    Albatron KM18G Pro
    Epox 8RGMI SKT A Nforce
    There is a MSI one and an ASUS one but I cant remember the model names and Google isn't finding them.
  4. chuckalicious
    chuckalicious
    Sep 15, 2004
    247
    +4
    Cheers. Great help
  5. chuckalicious
    chuckalicious
    Sep 15, 2004
    247
    +4
    Just looking at the Biostar one...
    It says it has a SPDIF header, which would mean you have to plug something into that header. Where would I get such a thing, or are there any that have the port already on the motherboard, instead of a headeR?
  6. tinoest
    tinoest
    Aug 19, 2005
    999
    +19
    There are some that have a port instead of a header the Gigabyte and the MSI ne i know have an port on the back. I would recommend the MSI one as I used to have it just can't remember the number. Now looking for it.
    MSI K7N2GM2-LSR SOCKET A NFORCE2
  7. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,801
    Caterham
    +59
    A7N8X-VM/400 perhaps?
    You'd be kind of hard pressed to find decent Socket A motherboard now, Socket A was retired a few months ago and I think production of the motherboards has pretty much grinded to a halt
  8. tinoest
    tinoest
    Aug 19, 2005
    999
    +19
    The Header's you can just buy seperatly from Ebuyer,Scan,etc
    They should come with one in the box tho if you buy new.
  9. Dunkwho
    Dunkwho
    Sep 3, 2001
    531
    28
    Dunstable
    +24
    Just been through a similar thing and had a gigabyte 7vm400 delivered this week (still in its box at home :( ). The asus a7s8x I already have is great and has an spdif phono socket on the back panel in place of an rs232 socket ... but the soundmax drivers just don't like mce and I've not been able to get a stable system that'll give me dd\dts for dvd playback (I've had stable, and I've had dd\dts ... but not together ! :) ). The gigabyte also has 3 pci sockets over the asus's 2 just incase I need to go for a pci soundcard as a get-out-of-jail. The gigabyte is 333 not 400 tho ... I went for the am-rz model for £36+del from microdirect (am = sata too). Shame, the asus was rock stable and didn't need any leads\backplate for spdif ... nice idea for a htpc mobo - works fine with non-mce apps apparently.
    Duncan
  10. chuckalicious
    chuckalicious
    Sep 15, 2004
    247
    +4
    This just get's more complicated!!!
    Beginning to wish I'd put more money into it and got a 64Bit AMD or a P4 :(
    Too late now. Maybe I should try an elcheapo SOund Card with a spdif first, might be easier to find and I won't cry as much if it doesn't work either :)
