New monitor with DVI, should I upgrade the graphics?
Ged
Just bought a new, larger (19") LCD/TFT monitor as the room is being refitted and the screen will be further away, my excuse ;) .
It also has a DVI input, my PC has onboard graphics to a "D" connector only, would a modest outlay to a DVI enabled card show an improvement? I mostly mess on the net and like to store my photos on the PC, no gaming.
Thanks.
Rambles
I have the option of both on my pc and monitor - I say yes, the upgrade is significantly better - text is sharper and colour more vivid.
Ged
Thanks Lisa, if I buy a new card can I just put it in the PC and it will recognise it or do I have to mess with the BIOS settings? I have never done a card install, only burners etc.
Ged
S
Skunkpipe
It will recognise it straight away. Sometimes there's a BIOS setting to set the Gfx Card detection order, but the default tends to be AGP first then PCI then on-board
D
DennisT
I agree, use the DVI. Much sharper clearer images.
Changing cards is easy. Just remember to uninstall the drivers for the old card first, or they can sometimes cause problems if your new card is the same make.
1. uninstall old drivers
2. change card
3. install new drivers
4. re-boot
Easy as that... have fun.
Ged
Thanks, now for the silly question....
Do I go to the System - Hardware section and delete the display driver and if so does the screen still work? I expect alot of people will laugh but I am not sure, so do I delete the driver, turn it off, fit the card then driver and reboot?
Really sorry for such a noddy question.
KraGorn
Yes, it'll still work. :)
Without any drivers Windows uses generic VGA support built into it, which isn't as capable as the installable drivers but work fine to display normal Windows programs (albeit window drawing etc. can be noticeably slower).
It's the same when you boot into 'safe mode', you have a nearly fully working display system just running slower.
KraGorn
To be honest, if you're not wnating to play games or watch DVDs then any card with DVI will do the job, so go for the cheapest you find .. IMX there are no 'duff' cards equipped with DVI connectors, and again, without needing to consider high-spec games or the fine details of video playback either ATI or NVidia will be fine (in fact, using a 19" LCD even IF you were interested in video playback then the choice of chipset would be moot IMHO).
oxygenuk
Thanks.
yes especially if you have onboard
go for a geforce 6200 as thats what i have and its great and it also have dvi input :)
Ged
Thanks,
placed an order last night for one of these
XFX Geforce FX5200 256MB AGP8X Graphic Card with DVI & TV-Out Retail
for about £40, hopefully should be ok.
One more question... is an 8ms response fast or slow? Had a bit of discussion at work as to whether lower is faster eg 8 faster than 25 or slower??
dan1979
Monitors that have DVI inputs usually have a sub-standard VGA port thrown in as a second thought so it's not actually the magic of DVI giving you better pictures.
BenW
Have to say my analogue dell tft going into the vga socket on a radeon 9800 PRO gives lovely sharp text and vivid colours. Took a while to get the colour balance right (Auto on digital monitors) but otherwise its excellent
Ged
Hi all, the new card arrived, had a go at fitting it and ended uo with constant beeping and no power up. Took out the new card. Ended up disabling something in the display setting and it now only displays during the inital set up, an older hard drive works ok.
HELP! How do I get the display back? I am going to try a new thread for some help.
BenW
Try using the old port, uninstall the drivers then put the new card in the boot up
Most probably a driver problem
Ged
Ben the cad is out as the PC wouldn't start and now I cannot see anything past the BIOS set up.
Podcast: Philips OLED+935 impressions, Denon AVC110 Review, Film Reviews, News and More...
