New monitor/LCD for my pc
Discussion in 'PC Gaming & Rigs' started by addyb, Sep 17, 2007.
  1. addyb
    addyb
    Nov 7, 2005
    35,466
    +12,295
    Hi all!!
    Well i was going to post in the LCD forum but thought this is more appropriate as its purely for pc gaming!
    Anyway i currently have a 19" ilyama crt monitor but have been entertaining the thought of getting a 20-22" lcd tv to use on my pc instead. Now I just wondered what the cheapest option is for a decent display for my pc. I have an X800XT gfx card.
    I have around £150 to spend. I basically want something a bit bigger (screen size) than my ilyama but obviously cost effective as well!
  2. Sinzer
    Sinzer
    May 25, 2002
    5,829
    +1,120
    I spend 180 quid on a Hanns G 223DP, 22" widescreen, it is a very nice screen. It doesn't work as a TV out of the box though, you need to connect it using a component -> DVI convertor. It also does not accept a HDMI signal.
    There are a lot of good suggestions in the monitor forum tho here :-
    http://www.avforums.com/forums/forumdisplay.php?f=276
  3. addyb
    addyb
    Nov 7, 2005
    35,466
    +12,295
    Ok thanks for that!!
    Yeh well it will be used purely as a display for my pc and nothing more. I havent bought a new monitor/lcd for years so im a bit behind the times!
  4. Tejstar
    Tejstar
    Dec 4, 2002
    22,998
    London
    +1,150
    There is some good budget 22" monitors, look at the one Sinzer mentioned, also consider the Cibox 22" monitor.
  5. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    if you own an Iiyama CRT then i'd suggest saving up more money and getting a high quality LCD of around 24in......otherwise going from a 19in high quality CRT to a 22in mid quality LCD just wont seem like a fair swap....that extra few inches really doesnt make much difference after a few weeks usage....moving to 24in will be more worthwhile....
    the sad thing is you wont get a lot for the CRT nowadays as so few people want them.....shame when you consider how good the images are....far more 3D than most LCD's manage....
  6. Tejstar
    Tejstar
    Dec 4, 2002
    22,998
    London
    +1,150
    True, but you'll have to consider whether your PC rig is up to the task of displaying games in the native resolution of the screen (1900x1200). Tbh I would think that you need at least a 8800GTX for those resolutions. Of course you can lower the resolutions that you play at, although it may not look as good as you want.
  7. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Very true. A 1920x1200 is a big res for gaming. A 8800GTX would be the card I recommend for that display. I would also recommend the Dell 24" display. Put both of them together and you will have a gamers wet dream. :smashin:
  8. plasmahal
    plasmahal
    May 3, 2007
    +3
  9. Tejstar
    Tejstar
    Dec 4, 2002
    22,998
    London
    +1,150
    Or the HW223DP is a good bet for just under £30 extra. It doesn't have HDCP but it has a host of features, like USB hub and component-to-DVi convertor, along with a robust design that is worth the estra imo.
  10. addyb
    addyb
    Nov 7, 2005
    35,466
    +12,295
    Thanks for the tips guys!!
    Now i just need some advice on a decent soundcard and speakers for my new system. (see my thread in the soundcard forum) :smashin:
  11. Tejstar
    Tejstar
    Dec 4, 2002
    22,998
    London
    +1,150
    I replied in that thread, but basically for your budget, those choices you have already made seems like the right ones. :thumbsup:
