willykatie
Bought Marantz amp and Monitor Audio BX5 AV and when i ran Audyssey to calibrate the speakers, i noticed that the sub making static/crackling noise all the way through the setup. Once the setup done, it doesn't make any of that noise at all and the sub working fine with film just only in audyssey setup it makes a really crackling or static noise and when i switch it off the wall, it makes a really loud thud/crackly noise as well (not just a thud but more like crackling thud like dirty line?). It doesn't make crackling noise when i powered down the sub from standby mode, just when its on.
Is this normal as don't think i noticed any crackling thud from my old amp and sub? I set the sub volume only around 9 o'clock hand and the crossover to max.
