New model NTL STB
Discussion in 'Cable TV & Virgin Media TV' started by calibos, Feb 28, 2003.
  1. calibos
    calibos
    Aug 4, 2000
    930
    Ireland
    +33
    I'll be upgrading to NTL Digital here in Ireland shortly. I heard that they are using a new STB since January but I haven't been able to find out the model number so that I can check the specs. I want to have the cables/convertors etc organised before the installer arrives. The old model STB they were using was the Pace Di4010 and the new one is apparently a cut down version. If it can output RGB then great I can order an RGB to S-Video convertor from Joe Fernand to hook up to my PJ. I have this terrible feeling though that it will only outpt Composite.:mad: Seeing as NTL Ireland usually follow the UK lead, have any of you lot got this new cutdown STB and can you tell me the specs or the model number??
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    I dont know if we are talking about the same thing but Samsung should be supplying some digital STB's to NTL this year.
    PACE have a cut down SKY STB but not heard of a NTL version.
