New memory stick testing...odd behaviour
Joe Pineapples
Joined
Oct 23, 2001
Messages
8,911
Reaction score
2,210
Points
2,253
Location
Doncaster
Just bought a SanDisk Ultra Flair 32 GB USB 3.0 stick and been testing it with crystaldiskmark and usb flash benchmark, with both giving similar results. That is, when I first plug the stick in, I get results about one third of those expected. If I then physically remove (software eject first) and insert it in the same socket, then re-run the benchmark, I get about the expected/rated speed. I don't know if its normal behaviour or if there's a problem, but obviously I don't want it defaulting to the slower speed if I need to use it as a bootable/install Win10 O.S (its main purpose).
(Running the benchmark twice without removing the stick gives the same slower result).
Possibly some sort of caching. The more important small file rates don't change much though, so I wouldn't worry about it.
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
