New member in need of some Plasma connection advice
Discussion in 'Plasma TVs' started by Tommo21, Nov 7, 2004.
  1. Tommo21
    Tommo21
    Hi everyone, please can someone give me some advice regarding connecting up my prospective Plasma.
    I am moving house a week on friday and will be purchasing a Panasonic 42PW7. I will be wall mounting it and want to connect the following;
    Sony PS2
    Sky Digital
    DVD
    Video (possibly!?)
    My current setup is SKy --> video --> 32" Panasonic Widescreen (AV1)
    DVD --> TV (AV2)
    PS2 --> TV (AV3)
    I understand that I will need a tuner unit (allow just one connection to the Plasma) which one for this type of Plasma ? I assume the tuner connects to the Plasma's component board ?
    Or am I incorrect in thinking that a scart board connecting into a scart selector could do the job (but picture quality may be worse ?)
    If anyone has any good tips for getting a better connection, particularly for the PS2,
    Many thanks
  2. Tommo21
    Tommo21
    Just sending it up to the top again, any help would be most appreciated,
  3. philipb
    philipb
    Mar 6, 2002
    1,980
    63
    Swindon
    +129
    Don't have a Panny. What inputs are available? And waht other gear do you have, eg an amp with component switching?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    PS2 either component or S-video
    DVD component (upgrade if needed)
    Sky use one of these http://www.av-sales.co.uk/html/rgb_to_plasma_scrren_vga.html
    to built in VGA socket
    Suggest you go for the dual slot terminal board and decide what the priority is for DVD and PS2 and use higher priority one to component and lower to S-video SKy to VGA (upgrade to sky+ and ditch VCR
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  6. Tommo21
    Tommo21
    Some interesting info..thanks.
    I am planning to get the PW7 which has a scart board included, so was looking to accompany it with the Quintro scart switch, running all the devices off this.
    As this is a wall mounted plasma I was thinking of restricting the amount of cablingm, so with the Quintro I would only need to run 1 scart and power to the plasma, as well as an amp connection (have a yamaha)
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    who were you going to buy from? AV-sales let you choose the input board... Scart is the worst input board available for the PW6/7 PQ is not as good as it should be...
  8. Tommo21
    Tommo21
    Looking to purchase here,
    http://www.toptelevisions.co.uk/shop/?target=dept_818.html
    or at http://www.crystaltec.co.uk/showitem.php?pid=732
    Its all getting a little confusing, but basically I want the PW7 with the relevant board that will attach to a device that can have the PS2/DVD/Sky fed into it.
    I assume one way was to connect it via a tuner (+relevant board on the Plasma) but obviously more costs are involved.
    The bottom line is I am having a Wall Mounted Panny 42 PW7, so need to keep cabling down to minimum and want to connect up the devices listed above !
  9. Tommo21
    Tommo21
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  11. Tommo21
    Tommo21
    Good question HD, not able to confirm what model my amp is (Yamaha) but if you know of a good website where I can spot it ! I will tell you now otherwise will have to wait till this evening.
    I'm no expert on the RGB conversion question I'm afraid.
  12. Tommo21
    Tommo21
    Found it ! its an av amplifier - Yamaha DSPA5
  13. Tommo21
    Tommo21
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    AMp has only composite S-video switching (no comopnent) so (possible cheat that may may not work for switching component............) so i suggest you run it all intio amp (lower quality) and the to screen or forget amp video switching for the time beimg and we start you off again mate
  15. Tommo21
    Tommo21
    Sounds about right, thanks for the recommendation on the video matrix switch, looking at;
    PW7 (Crystaltec for price plus has component board inc)
    Wall mounting (Av-sales)
    Matrix switch (Av-sales)
    Cabling - relevant component cables for the devices !
    Also - PW7, PW7B - the difference being ?
  16. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    B means UK and i suggest you get that from AV-sales drop alistair a line.... also pick up the extra warranty from them extra 2 years cover for £199 well worth it...... + I know there stock is genuine UK and i was sure you got a component board as well in the price (dont skimp on this) if it buzzes or turns up dead you need a company who can sort it....... not flap for days and then **** you off.....
  17. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Also as amp does switch S-video i reconmed you use a 5 core video cable and have it terminates 2 cores to S-video (4 pin mini DIN plug) + 3 xBNC on one end and S-video + 3 X RCA on the other end that would allow you to use the dual slot board and then connect any extra devices via S-video and the amp AV-sales should be able to supply Van damme 5 core or QED CX5CV ( a bugger to bend) terminated like this so just one cable + power to screen (CX5CV is lovely green colour) but allows you to use almost all devices (standard VCR is the only thing that wont output S-video or component that you are likely to want to use )
  18. Tommo21
    Tommo21
    Thanks again HD, so are you saying with the correct cabling, I could connect my Sky/DVD/PS2 into the amp which then connects into the Plasma with the correct board (saving the cost of a video matrix switch ?)
    Trying to fathom out the cabling plan you have mentioned.. :laugh:
  19. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    YES DVD direct by component Sky via S-video (RGB>Svideo converter or upgrade to Sky+) PS2 via Svideo (just buy the lead) and run S-video to screen, Sky and PS2 via amp or could connect them all to a quintro and up to RGB>VGA converter and off to VGA on plasma...... There are loads of options mate just need to work out what works for you...
  20. David
    David
    Nov 26, 2002
    221
    16
    London
    Just how bad is the Scart board on the PW7? I've just ordered one with a Quintro box. all the equipment I have has scart connectors (RGB or S-Video) though so not really a choice is there?
  21. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    there always is mate some peole hate it some think it is OK but as some are happy you could well be...... but with the JS box costing the same as the scart board its a close call, Where have you ordered from???
  22. David
    David
    Nov 26, 2002
    221
    16
    London
    AV Sales. Due for delivery on Thursday. Its the TH37PW7 by the way.
  23. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    well as you didnt pay for the scart if you think the PQ is too soft then you just plump for the JS box once you have seen it running mate....
  24. Tommo21
    Tommo21
    JS box ?
  25. David
    David
    Nov 26, 2002
    221
    16
    London
    Does the JS box accept scart inputs but have either component or VGA output then?
  26. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  27. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    converts RGB Scart to VGA accepted by most plasmas
  28. David
    David
    Nov 26, 2002
    221
    16
    London
    Looks impressive but how many scart inputs does it have and does it also accept S-Video in via scart?
  29. Tommo21
    Tommo21
    Okay..HD, I have been inspecting the rear of my AMP which is as follows;
    Video (yellow connectors)
    O O O O O
    DVD/LD SAT VCR IN VCR OUT MONITOR OUT
    Audio (white / red connectors)
    O O O O
    O O O O
    Can this be done using component cables
    O O O O
    DVD SAT PS2 PLASMA
    O O O O
    O O O O
    DVD SAT PS2 PLASMA
  30. Yorkieblade
    Yorkieblade
    Hi Tommo,
    I am a novice also reading this thread you know more than me why did you go for the panny pw7 and not the Panasonic Viera TH42PE30CAB Plasma?
    was it just the price diff?
    what do u get more from one to the other ?
    do you get picture in picture on the viera?
    I know you get a 100 channel freeview tuner built in the viera.
    Have you bought your pw7 yet ? was it around 1700?
    The viera is around 2400 from John Lewis with 5 year warranty.
    Help im lost what's this extra board people are talking about ? is it built in to the plasma or a seperate box of tricks?
    I want a plasma that I can connect :-
    sky
    dvd
    pc
    ps2
    sorry for so much trouble
    Yorkie
