New member, go easy and please help- advice on MA silver or gold series
Discussion in 'Home Cinema Speakers' started by birdseed, Nov 17, 2004.
  1. birdseed
    birdseed
    Nov 17, 2004
    229
    +5
    Hi all, just found this forum via a search engine, and im looking for some ideas on what to do next with my setup.
    Im willing to spend a grand to finish things off.
    I have now a harman kardon av230 amp.
    MA bronze bfx rear
    MS 309 sub
    10 yr old MS10i im using at the front.
    I need to get a centre and fronts.
    The local 7oaks is helping out, so heres the options
    Silver centre, s1 or s2 and a new rel sub for £500 or the quake at £350
    Silver centre, s6or s8, and keep the current sub
    Second hand gold centre and GR10s, keep the current sub or upgrade later
    My room is 15x10 and the TV is in the corner, and the two fronts would be in each corner.
    Im looking to move house late next year, and dont want to change speakers then, as ill be looking to buy a plasma at that time.
    Basically is the cheap sub i have sufficient to make up for what id lose with a bookshelf, or should i go for the s6 and s8s?
