New MCE Nvidia drivers (official)..
Discussion in 'Microsoft Windows' started by Rambles, Jun 21, 2005.
  1. Rambles
    Rambles
    Jul 14, 2004
    8,489
    UK
    +1,357
  2. GazH
    GazH
    Apr 17, 2004
    445
    On the corner of Wabash and Lake
    +75
    Hi Lisa,
    Have you had a chance to try these drivers yet ?
    I am having problems finding a stable driver for MCE on my system...last night I actually installed v66.77 and it was the first driver I've installed that didn't crash the PC at the Welcome screen (on reboot tha pc fires OK but sometimes has a problem when entering Media center).
    I might as well give it a go tonight and see how it works...can't do too much on my system at the mo as my Nvidia DVD decoder trial ran out last night and Nvidias online shop is down until July...have had to order from scan and wait for it to arrive... :(
    Gaz
  3. Rambles
    Rambles
    Jul 14, 2004
    8,489
    UK
    +1,357
    Hi Gaz,
    Yes just installed these drivers and they work, so that's a good sign.
    The only other drivers that I have got to be stable in MCE were 67.66, but as they are quite old, not sure if they fully support Pure Video...
    Anyway these new ones seem stable, although too soon to be sure.
    The Nvidia DVD codec site has been down for maybe three months? Keep checking thinking they will release an update for the codec. Can't scan just e-mail you the activation code, what are they sending in the post??
  4. GazH
    GazH
    Apr 17, 2004
    445
    +75
    I presume the decoder on a disc and the activation code....is this not the case, do they just send the code ???
    Gaz
  5. Rambles
    Rambles
    Jul 14, 2004
    8,489
    UK
    +1,357
    I bought mine from Nvidia before their webshop went down... just got e-mailed an activation code which unlocked the 30 day trial ending...
  6. ttone
    ttone
    Not sure if any of you can help me out, I have recently built my first HTPC and as a result have just forked out a small fortune on a Loewe Xelos A32.
    I am running Windows media centre edition and do not seem to be able to set the screen resolution any higher than 1024x768. The native resolution of the TV is 1366x768. I have a Gigabyte 6600gt graphics card.
    Basically when I try any resolutions above 1024x768 I either get a blank screen or half of the windows display is shown on the wrong side of the screen.
    Help !!!! It is really starting to P me off.
  7. DaveP
    DaveP
    I'm not familiar with your tele but I am taking an LCD set back that I just bought because it would ONLY run 1024x768 on VGA. To get the max resolution you need to use the DVI connection.
    Maybe it's the same for you.
    Dave
  8. ttone
    ttone
    Dave, the tv is a HD LCD. I am also using DVI input so I am at a loss, I'm sure someone out there has had the same problems, I just need to find them.
  9. DaveP
    DaveP
    Surely Loewe have a help line? Have you tried them?
    Also, are you running DVI to DVI or DVI to HDMI?
    Dave
  10. ttone
    ttone
    the tv is so new that Loewe UK do not have much knowledge of the product yet, I have tried!!!!!
    I am running DVI (PC) to HDMI (TV) via an adapter
  11. DaveP
    DaveP
    ISTR that this can be an issue (DVI to HDMI). Some HDMI devices don't like PCs.
    It may be worth you looking for a similar problem but with a Sharp panel.
    There is a forum here that may be worth checking out.
    I assume you have tried Powerstrip? It has some pre-defined resolutions for LCD screens but you may need to get some parameters that suit the Loewe.
    I had terrible problems getting my Sony pj (also 1366x768) to work with DVI to DVI.
    Dave
  12. TheCrow
    TheCrow
    Jul 16, 2004
    660
    2
    28
    London
    +76
    Noticed a new version 1.02.145 of the DVD codec but it states "This version of the decoder has only been tested on GeForce 7800 GTX" so don't know if it will work on a 6600GT. And I can't make the download work at the mo'.
    Still at least they are developing new versions.
  13. TheCrow
    TheCrow
    Jul 16, 2004
    660
    2
    28
    London
    +76
  14. TheCrow
    TheCrow
    Jul 16, 2004
    660
    2
    28
    London
    +76
    Sorry to keep posting, I feel like I am talking to myself :oops:
    But reading the release notes it doesn't mention anything specific to 7800GTX infact there is a list including most modern GPUs such as the GeForce 6 series chips.
    It also mentions support for MCE 2006!
    I'll let everyone know if they work with a 6600GT tommorrow as I am still at work at the mo'. Unless someone else beats me to it.
  15. Rambles
    Rambles
    Jul 14, 2004
    8,489
    UK
    +1,357
    Interesting stuff.... is this an upgrade to the Codec we have already purchased, or a new one that they want more money for? Not even heard of a 7800GTX :confused:
    It does say that their store will be back up on 8th July, maybe we will have an upgrade to our existing codec then... about time they got their website sorted with proper information and support on it :lesson:
  16. TheCrow
    TheCrow
    Jul 16, 2004
    660
    2
    28
    London
    +76
    It's nVidias latest GPU and was actually released today!
  17. DaveP
    DaveP
    I installed this this morning and used my original activation key etc. and it seemed to install OK. I'll do some more testing tonight, if I get some time.
    Dave
  18. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Download the latest drivers from nVidia or get a utility called Powerstrip that allows you to create custom resolutions. You'll probably only be able to get 1368x768 as 1366 isn't divisible by 8.
    Richie.
  19. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    For more info on the 7800GTX check this review here
  20. TheCrow
    TheCrow
    Jul 16, 2004
    660
    2
    28
    London
    +76
    Same here, installs OK, accepts original key and appears to work OK at first glance.
  21. Spacecat
    Spacecat
    Apr 1, 2001
    3,363
    London
    +1,011
    does it improve picture quality in Live Tv or recorded Tv at all?
