loafer27
Established Member
ok from a little bit of research it seems the new mac minis come with an integrated intel GMA 950 as well as a 1.66 core duo processor
the specs of the 950 gfx chipset look promising
any thoughts?
Intel® Graphics Media Accelerator 950 Graphics Core 256-bit graphics core running at 400MHz
Up to 10.6 GB/sec memory bandwidth with DDR2 667 system memory
1.6 GPixels/sec and 1.6 GTexels/sec fill rate
Up to 224 MB maximum video memory
2048x1536 at 75 Hz maximum resolution
Dynamic Display Modes for flat-panel, wide-screen and Digital TV support
Operating systems supported: Microsoft Windows* XP, Windows* XP 64bit, Media Center Edition 2004/2005, Windows 2000; Linux-compatible (Xfree86 source available)
High Performance 3D Up to 4 pixels per clock rendering
Microsoft* DirectX* 9 Hardware Acceleration Features:
Pixel Shader 2.0
Volumetric Textures
Shadow Maps
Slope Scale Depth Bias
Two-Sided Stencil
Microsoft* DirectX* 9 Vertex Shader 3.0 and Transform and Lighting supported in software through highly optimized Processor Specific Geometry Pipeline (PSGP)
Texture Decompression for DirectX* and OpenGL*
OpenGL* 1.4 support plus ARB_vertex_buffer and EXT_shadow_funcs extensions and TexEnv shader caching
Advanced Display Capability Up to 2048x1536 resolution for both analog and digital displays
Consumer Electronic display (Digital TV) support
Display hot plug support to automatically detect new display connection while system is operating (CRT and DVI)
Two Serial Digital Video Out (SDVO) ports for flat-panel monitors and/or TV-out support via Advanced Digital Display 2 (ADD2) cards or Media Expansion Cards
Intel Media Expansion Cards available providing TV-out and PVR capability
Multiple display types (LVDS, DVI-I, DVI-D, HDTV, TV-out, CRT)
Dual screen support through ADD2 digital video devices
HDTV 480i/p, 576i/p, 720i/p and 1080i/p display resolution support
Interlaced Display output support
16x9 and 16x10 Aspect Ratio for widescreen displays
2x2 Panel Scaler
Stunning Video Playback High Definition Hardware Motion Compensation to support high definition hi-bitrate MPEG2 media playback
Up and Down Scaling of Video Content
High Definition Content Decode - up to two stream support
5x3 Overlay Filtering.
any thoughts?
Pixel Shader 2.0
Volumetric Textures
Shadow Maps
Two-Sided Stencil
2x2 Panel Scaler
