New LG TV - No sound on start up from Sky box?
BigDarbs
Hi, I have an LG Smart TV (UK6400PLF). When it is initially turned on there is no sound from the Sky box, on the HDMI input.
If I turn the Sky box off, to standby, then turn it back on again I get sound from the TV. Clearly it can't be a problem with the lead as I wouldn't get sound at all.
Does anyone have any thoughts how I can get the TV to fire up with sound from Sky?
dts
What sky box so you have? Sky + HD or sky Q?
JayCee
Try rebooting the TV and Sky box by unplugging them from mains power, plug them both back in, wait 2 minutes and then switch on.
BigDarbs
Thanks for this, but I have just tried it with no luck. It all boots up, with picture from Sky but no sound, if I turn the Sky box off (onto standy) then back on I get picture and sound.
JayCee
Go into the Sky box sound settings and change it from “Dolby D” to “Normal”
Don’t forget to save the setting.
dts
Try these settings.
dts
And these for sound settings HDMI audio output want to be on stereo instead of Dolby digital unless you have it connected to a av amp or soundbar.
