new lg plasma connectivity-42px3rva
martd77
My lg plasma tv is due to be delivered this week can anyone advise me the best way to achieve the best picture possible using quality cables.
In my set up i have a panasonic th70 dvd home theatre system and a sky+box.
Are quality scart cables the best way to ensure optimum picture quality or is component video the solution?
M
Member 34135
If your DVD system supports component then that is best for DVD, even better if both support prog scan. For Sky use either a fully wired scart lead or RGB only if you don't want sound piped to the TV, and make sure the video out is set to RGB on the Sky box.
Andy.
martd77
thank u i will go with that suggestion as the dvd player supports component,as regards sky using the rgb socket on thetv does produce tv sound which i have to turn to zero si i presume it s a crap quality scart lead which i will immediately replace
thanks again
🎬 Across the Spider-Verse, Fast X, Covenant, Sisu, Changeling 4K, Lighthouse 4K, Quantumania 4K & TV
Back
