Quantcast
New Lenovo Laptop Problem
hannah19999
I got a new Lenovo IdePad Z570 for Christmas and it's brilliant. However, it has internet connection problems.
Even though I sit in the same room where the router is, sometimes Lenovo just refuses to connect with the internet and when it does, the connection just stops after a couple of minutes.
Also, when I take it upstairs, even though it says that the signal strength is excellent, it doesn't connect.
Is there anything I could do with it or should I just call Lenovo and give the laptop back to them, so that they can repair it?
Thanks for help.
maf1970
Download and install InSSIDer on your laptop. Then run it and it will show you a map of the routers and what channels they are using in your immediate vicinity.(including your own).
