ringwraith24
Hi All,
So I recently got into a new apartment and have been upgrading my AV gear. Started with a 65" TV added 2x10" monoprice monolith 10" THX subwoofers. The last remaining bit is the speakers. I have an old Polk monitor 30s (with CS2 centers) which are clearly no match for the subwoofers and are not really that great for music. They are ok for movies though along with the CS2 and the subwoofer doing most of the heavy lifting.
Looking for recommendations on upgrading the LCR set (preferably bookshelves) to something that is good for music and movies alike and doesnt cost a bomb (max budget of £1K). Dont really have the ability to run surrounds as it is a multi purpose room, but I would be happy with a good LCR. Open to buying used speakers as well. The room is an open plan living room and I typically listen at low/medium volumes. I am not in a hurry though as the current system is serviceable, so can wait for a good deal. Browsing through the reviews, monolith 365s (when they are on a deal) could be a good option, but I don't really need the THX volume levels. I hear they sound good at low volumes as well and when on a deal could fit my budget.
Thanks!
PS pic of the current setup so you know what I am working with.
Thanks!
