New LCD & widescreen settings - help required
Discussion in 'LCD & LED LCD TVs Forum' started by teenageprodigy, Mar 28, 2006.
Tags:
  1. teenageprodigy
    teenageprodigy
    Mar 22, 2006
    25
    I realise this is most likely the dumbest question you've ever had on here so apologies. I'm a widescreen virgin.
    Just got a new Tosh 37wlt58 (v.happy) but I still seem to be losing the edge of my pictures from my Sky box. I've got it set to 'wide' picture format but no good.
    TP
  2. madfish_den
    madfish_den
    random guess,
    have you gone into sky -> services -> picture settings and changed the output style to 16:9 from 4:3?
    Denny
  3. teenageprodigy
    teenageprodigy
    Mar 22, 2006
    25
    Shocking. I am truly embarassed. :oops:
    Mind you, I guess that's what anonymous internet forums are here for.
    Cheers!
  4. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    also set the tosh to an aspect ratio of 16.9, they are set at automatic at factory for default,and for some reason sky always comes up as 4.3.
    you will find this in the menu under settings.
  5. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,367
    And in the Sky box settings change the output from Pal to RGB if you want a better picture, do not forget to save.
  6. teenageprodigy
    teenageprodigy
    Mar 22, 2006
    25
    Don't seem to have an option for this under picture setting?
  7. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    it is in set up, not picture settings
