New LCD TV as a PC Monitor ?
Discussion in 'LCD & LED LCD TVs Forum' started by Kings, Jan 21, 2008.
Tags:
  1. Kings
    Kings
    Jul 28, 2004
    12
    I am just about to buy a new PC from Evesham, I was wondering could I use a new HDTV TV as a PC monitor rather than a specific normal LCD monitor ?
    I would like to buy and use a new HDTV for my Xbox 360 and if possible also connect the PC to the same screen.
    Is it possible ? Has anyone else tried this ?
    Would appreciate some input, thanks very much
    Kings :thumbsup:
  2. morettat
    morettat
    Nov 12, 2002
    Herts, UK
    Yes - definitely.
    Either from VGA to VGA (check TV has one) or preferably HDMI to HDMI or DVI to HDMI.
    I'm running a new Dell with a Toshiba 46" LCD, via a DVI to HDMI lead.
    DVI/HDMI will allow you to run at maximum resolution for the TV, whereas most TVs limit the resolution via VGA.
  3. brain_stew
    brain_stew
    Sep 12, 2005
    696
    28
    +32
    If you're going to be using it as a PC monitor, then you'd see a real benefit from a 1080p screen.
