New lcd in bedroom, best way to connect?
Discussion in 'Freeview & YouView' started by psycho74, Jun 2, 2008.
  1. psycho74
    psycho74
    Aug 23, 2005
    Witham, Essex
    +4
    Hi all, i have just put a new lcd tv on the wall in the kids room, there is no aerial socket in the room and i know indoor ones are said to be crap so with an aerial lead going into my sky box downstairs, is there a way to run that signal upstairs? Maybe there is an even better/simpler solution that you can suggest?! Many thanks in advance. :thumbsup:
  2. lfcmonkey
    lfcmonkey
    Mar 26, 2007
    1,219
    Doncaster
    +105
  3. Sonic67
    Sonic67
    Sep 14, 2006
    43,229
    11
    167
    Home
    +21,259
    Is your aerial in the loft? Could you split the co-ax and then run a cable down the corner of the room and into the TV?
  4. alchemistkevin
    alchemistkevin
    Sep 6, 2007
    3,632
    Surrey
    +133
    I did a split once but the signal strength meters in the DTV software said signal stregth drops!
    something to keep in mind, but if you want to have a go, buy some cable and a y-splitter - that's what I did....
    hope it helps :)
  5. Sonic67
    Sonic67
    Sep 14, 2006
    43,229
    11
    167
    Home
    +21,259
    I have the TV's coax go from the aerial into the loft, from there it is amplified and then split four ways to two upstairs bedrooms and two downstairs rooms. A lot depends on how good the signal was in the first place etc.
  6. psycho74
    psycho74
    Aug 23, 2005
    Witham, Essex
    +4
    Our aerial is located at the end of our block and is shared by six other houses, we just have a socket behind the tv in the front room which is wired into the sky box. Which is why i was wondering if running another cable upstairs would be the best solution, also would i be able to take advantage of the bedroom tv's freeview tuner this way or would i need an altogether different cable for this? :lease: :D
  7. JayCee
    JayCee
    Jan 20, 2004
    23,214
    Lanarkshire
    +2,484
    Yes.
    If the signal is strong enough that will work okay.
    Use a good quality double-screened coax cable...not the thin stuff that the D-I-Y sheds sell...try it and see.
  8. psycho74
    psycho74
    Aug 23, 2005
    Witham, Essex
    +4
    Is there anywhere online that you can buy already terminated lengths of coax cable? I presume without checking that i would need a female plug for the skybox end and a male plug for the tv upstairs? :thumbsup:
