New laptop advice.
hornydragon
Morgan have some good deals on Tosh I would go for a robust machine with good connections dont worry about weight (unless its carried to lectures) i killed 2 laptops as a student (both cooked with over use and batts died quickly) so i would say go for a named brand as they are far longer lasting ACER arent great for longevity for entertainment genral use something like http://www.morgancomputers.co.uk/shop/detail.asp?ProductID=2017&CategoryID=11&SubCategoryID=239
for more office based stuff http://www.morgancomputers.co.uk/shop/detail.asp?ProductID=3504&CategoryID=11&SubCategoryID=222 Morgan seem better than they used to be, but i havent used them recently
Graham27
If you do decide to go with an Acer laptop check Comet online before you buy. I've been looking for one lately and Comet have been far cheaper than anywhere else for certain models. I don't think they have the 5602 but they do have the 5612 model for £599 which has 1gb ram instead of 512mb and also has an 80Gb hard drive rather than 60gb.
I've also heard that Acer maybe aren't as tough as some other brands but to get another brand with similar spec usually costs a fair bit more.
It's also always worth keeping an eye on Dell to see if they have any crazy offers on at the mo. Deals can change weekly so it's worth checking up. Keep an eye on the section that shows you the machines that are being advertised in the press/media as these tend to be the more spectacular deals.
It's a bit of a minefield choosing a laptop at the mo (well, always actually!), good luck !
Uridium
Graham27 said:
If you do decide to go with an Acer laptop check Comet online before you buy. I've been looking for one lately and Comet have been far cheaper than anywhere else for certain models. Comet currently have the 5612 model for £599 (the site you linked to has it at £659) which has 1gb ram instead of 512mb and also has an 80Gb hard drive rather than 60gb.
It's always worth keeping an eye on Dell to see if they have any crazy offers on at the mo. Deals can change weekly so it's worth checking up. Keep an eye on the section that shows you the machines that are being advertised in the press/media as these tend to be the more spectacular deals.
Best Dell bargains to be had are at www.dell.co.uk/outlet
