So my VPL-HS10 lamp is nearing the end of its life (done 2850 hrs since August 2003 and still going but getting a bit dim) Now do I replace the lamp at about £300, unless someone knows a cheap supplier or do I replace the projector?
I wouldn't want to spend much more than about a £1000 and don't know if that would get me anything better than I already have?
A couple of other points, the position of the projector is fixed so any replacement would need the same sort of throw as the HS10 and as the wiring is buried into the walls and ceiling I am stuck with the Sony cable (component s-video and composite all in one) which only fits the HS10 I guess and a DVI cable, I bet not many modern projectors come with DVI input.
Any thoughts or suggestions
